Amp help plzzz anyone
Username: Basssjunckie
Post Number: 21
i have a rockford p550 amp running a 12" kicker cvx wich is 750 watts rms and when i have a my sub running for like not too long the amps feels fairly hot but i have a heat sensor that turns it off when it gets to hot.. so is this normal for an amp to get hot?
Username: Wylie_coyote
Post Number: 44
the amp will heat up but it shouldn't get so hot that it turns its self off, i would say check that the gain isn't too high. also you may need to put in sum case fans to circulate the air in the boot. check e-bay they have some decent prices
