Hi, i have a flu receiver with two lnb for 119 and 110 i don't know what happen since yesterday i can only get 119 no 110, and i did a factory setting moved the dish still nothing, also my lnb i used to get 119 on it i had to swith it to the other side because no signal and quality on it does some one have a idea thanks
Re-ailign your dish,make sure to put cable directly into reciever will doing so .Repeat this process for your second sat also,then attach your diseq switch,and set your antanae setting apropriately to correspond with the switch connections.Then do a factory reset,followed by a fresh scan.
i think i have two problems one with the switch in the other with one lnb because i have signal only if i put the lnb 110 at the place of 119 if i put it back i can only have the level no signal
Today is sunday,try them tommorrow,on monday.Adjust your ant skew ,seldom lnb goes bad unless its severly abused.if your getting a signal ,poor quality when its connected to reciever,its your ant adjustment,not your lnb.
