The perfect match
Username: Basssquared
Kansas
Post Number: 555
I think i finally found the perfect amp for my 12" dual 4 ohm L7s what do you guys think about this amp? MTX TA81001
Kansas
Post Number: 557
Username: Nd4spd18
Southeast PA
Post Number: 2898
Good amp but MTX stuff is usually overpriced for what it is, compared other good brands.
Username: Mmaudioconcepts
Murray, KY
Post Number: 276
overpriced and s/n ratio of 68..
Kansas
Post Number: 558
so 400 shipped for this amp is too much?
Username: Nd4spd18
Southeast PA
Post Number: 2902
holy s!it thats a ripoff, lol. You can get good amps that do 2x the power for that price.
Username: Rovin
4 10 Pioneer...
Post Number: 11630
should look @ Hifonics which = good bang for $ ......
Username: Nd4spd18
Southeast PA
Post Number: 2908
He can get much better quality with that budget........ look into US Amps. In fact I think low-hz sells them Kevin could prob. get ya a real nice amp for that price.
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 7813
Now US Amps is some high priced sh!t. lol
Kansas
Post Number: 565
well i remember kevin trying to sell me a Sundown for 450 so i thought an MTX amp was good quality at 50 dollars cheaper
Username: Nd4spd18
Southeast PA
Post Number: 2920
Sundown = WAYYYYY better than MTX. Not even in the same league.
Post Number: 7815
fu*k MTX
Look at an ED NINe.1 www.elementaldesigns.com
Orion 1200D
Kicker KX1200.1
Orion HCCA D2400
Kansas
Post Number: 566
Hey logan all of those amps you listed are rated at around 1200 watts but i need one that does 1500 at least right now im using a memphis 1100 watt amp so that would be dumb to spend extra money just for 100 watts that wouldn't be noticable so now that i think about it am i even going to notice a difference from 1100 watts to 1500 watts?
Username: Ctmike
Ct.
Post Number: 4545
aren't you using a prd 1000.1d? if so that kicker will do more power than it, so will the ed. don't have personal experience with the orions' so i won't comment. both the kicker and ed will be closer to 1500wrms on a good charging system.
but like the others said, get the sundown amp.
Kansas
Post Number: 567
yeah thats the amp im using but even though im going to go from 1100 watts to 1500 thats only a 400 watt difference so my question is "is it worth doing?" i mean will there be an audible difference or only if i got it metered because i remember lil rob telling me that for me to be able to hear the difference i had to double the power which that wouldn't be
Username: Northomaha
Post Number: 411
hifonics bxi2006d for 340 i think. best deal
Username: The_image_dynamic
San Diego
Post Number: 1613
Wow.... 68dB s/n I had to look that up to even believe it was true. Now you have to realize that a s/n close to 70 is not audible in a car environment, and it would be nearly impossible to tell the difference between an amp with a 90dB s/n and one with around 70dB, with everything else in the system being equal. But....it is an indicator of quality engineering and the parts that are used without a doubt.
I didn't realize that MTX had slipped that far but you would be hard pressed to find an amp with a noisier rating than that, assuming that rating was taken at full power and not one watt. Add in the fact that almost all manufacturers milk the crap out of their s/n ratio figures.... if that is all MTX could do, then that is one pile of shit right there.
