Bronze Member Username: Stardumb
Post Number: 14 Registered: Jun-04
Posted on I just picked up an Alpine 12'' Type-E subwoofer for $25. I want to install it in my Infiniti G35 6MT. I'm currently using the stock audio setup. How would you recommend powering the sub? What amp, wire gauge, wiring setup, etc. Any advice would be greatly appreciated. Thanks, Steve |
Silver Member Username: Sheriff
Post Number: 453 Registered: Jan-07
Posted on Budget? |
Post Number: 454 Registered: Jan-07
Posted on Alpine MRP-M450 would work well for it. And use 8 gauge wire. |
Silver Member Username: Jkidder
Spring hill,
Florida
Usa
Post Number: 746 Registered: Nov-05
Posted on 35K car with a 25 dollar sub |
Post Number: 15 Registered: Jun-04
Posted on I'm looking to spend ~$200 more. What do you guys/girls think? |
Post Number: 16 Registered: Jun-04
Posted on The reason I bought it was because it was so cheap. I got the box and sub for $30. So I decided to go ahead and put together a small setup. I'm looking to spend ~$200 more. What do you guys/girls think? |
Gold Member Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 7878 Registered: Feb-06
Posted on What Corey said "Alpine MRP-M450" |
