Box painting
Username: Wolfman1966
Http://www.realmofexcu..., See my KRAZY... USA
Post Number: 3116
OK, SO I want to paint my box, can I do it with the subs still in it? maybe put masking tape around the outer part and paper over the sub itself? I'm gonna spraypaint it black, so colorwise that shouldn't hurt anything
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 5274
yes u can do it like that but if you paint it you have to first use primer and then use a fine sand paper and sand it and let it dry.
from there apply another coat of primer let it dry again. and then hit the black paint. at the end you can use clear coat that gets your really good results :-)
but taking the subs aout will be alot easier and sometimes around the woofer youwill miss some spots :-)
Post Number: 5275
if you dont use primer the box will look really crappy and the color will fade on some spots and the mdf wood will suck the paint making it look really crappy
Post Number: 3118
just really don't want to go through all the trouble of removing the subs, but it sounds a lot easire if I do....so I got to get sandpaper (what grit?), spray on primer, and then whatever color I want to use too, right?oh, and clear coat to make it pretty at the end.
Username: Jblanford
Post Number: 1218
man just make it easier for yourself and take the subs out...its not that hard
Post Number: 3120
also wondering, I am thinking about using some of the walmart version of the spray on bedliner...is that any good?
Post Number: 5277
the grit doesnt really mater btu try to use the finest as you can.. i beilve theres 1000 grit or 800 that its called the fine sand paper use that. you wil only be needing a bottle of blackpaint or watever color you want a bottle of primer and finally the clear coat.
yes foloow the steps i told you when you get finished of sanding it let it dry apply the other coat let it dry make sure all is smooth when u end up with the primer if not add more coats of primer let it dry, then use the black paint, let it dry use another coat of paint let it dry and at the end use the clear coat.
the clear coat will make the black apint hard to come off and will give a finish that its really cool and shiny
Post Number: 3122
rob>what about the walmart bedliner stuff? ever used it on a box? how hard is it to use? does it work good?
Post Number: 5280
bedliner is easy to use but doesnt looks as clean as painted like i told you,
the bed liner well you have to by a paint or beliner but it comes with a sealer i think . you have to use the sealant and like prime it. when you get done spraying the sealer you have to put the bed liner. some bed liners i think dont use the sealar.
Post Number: 3123
OK one more question for everyone that sees this post....
Everyone paints their boxes black, I'm thinking of possibly going with another color...how about some suggestions....and anyone that says PINK is a f@g
Username: Basssquared
Kansas
Post Number: 535
match it with the exterior of your car
Post Number: 5289
pink in a car is pimping. pink in cars had be used by pi mps and pi mps only no fa g s some girls but on their crappy beetles.
you can paint it any color you want is up to you.
i say black and put some take on your box and make a blue stripe. if u havent seen my box i left some areas unpainted to make it look real good.
Kansas
Post Number: 538
you mean you left some areas unpainted porque eres guebon lol jk man
Post Number: 5293
na dude it looks really good :-)
hers the vid of my subs unpainted http://youtube.com/watch?v=clb7iCNiV7w
and hers a pic of painted http://i79.photobucket.com/albums/j128/extrmndor3/03-27-07_1627.jpg
i did all the steps that i told you wolfie its up to you imagination on wat final thing you want.
Post Number: 3124
interior of the car is grey, kinda boring, I was thinking of something bright...purple maybe or red...maybe a metallic color
Post Number: 5296
dude do liek i did instead of letting the unpainted area you can get a grey spray paint and it will look really good.
Kansas
Post Number: 543
yeah it looks clean guey nice contrast between the black and the wood
Post Number: 3125
Rob, I don't really want grey, I want something that will stand out...I'm thinking a metallic red...for some reason, or maybe a metallic silver.
Kansas
Post Number: 544
Paint it to match your sword LOL LMAO
Post Number: 5299
wel its up to you wolfie but i say umm hey how abotu chrome??? you canpaint the box all black.
you can get like a really wide stripe on pepboys for about 10 bucks and put striped on your box like logan with his alpha box but instead of the white lines chrome lines to really make it stand out.
Post Number: 3126
HMMMM, chrome box all the way ...ftw....lol, don't think thats possible
Kansas
Post Number: 548
not with that attitude but that would be way to shiny anyways i think he meant just a couple of stripes not all chrome
Post Number: 3128
and whats wrong with shiny? I am still thinking about a metallic silver finish.
Kansas
Post Number: 549
i thought you were trying to keep your system low key and away from Mrs.Wolfman lol and shiny is not low key
Post Number: 3129
she wont see the box so wtf diff does it make, lol..I'm going to bed,and I'll recheck the thread tomorrow in case anyone else has some Ideas....good night.
Kansas
Post Number: 550
last time i try to give you suggestions
A pic is worth 1000 posts!!
Post Number: 7003
"and whats wrong with shiny? I am still thinking about a metallic silver finish."
Man you HAVE to post pics of that.
Username: Mesodumm
Tri-City, Az Usa
Post Number: 133
http://www.krylon.com/main/color_product_viewer.cfm?productid=1770&sub_levelid=8 &image_directory=/images/products/large/&image_name=make_it_stone.jpg&image_alt= Krylon%C2%AE%20Make%20It%20Stone!%C2%AE%20Textured%20Paints
have to copy all of link and paste in browser. For some reason this stupid thing doesn't keep it together.
Username: Drumma
Indianapolis, IN USA
Rob when painting ports, should they be primered first, before the black paint is applied? Thanks in advanced!
Post Number: 3131
Paul. gonna go to Autozone and see about the Metallic Silver
Post Number: 7006
Username: Adam_s
Post Number: 1251
Chrome paint FTMFW!!
Username: Van_man
Boston South, MA
Post Number: 2480
leaf it in Pure gold FTMFW. Forget spray paint.
But if you were to paint, Prime, sand with 180-220 grit, then paint. If you want a mirror finish, sand with 800-1500-2000 then buff it out with rubbing compound then buff with wax. You will need a least 2-3 coats of paint for that. Oh, Use a palm sander. Smother finish.
Post Number: 5336
first of.... you will never get full chrome out a spray can... it will look like mainly silver not chrome....
Username: Van_man
Boston South, MA
Post Number: 2481
^^^ Not true. You can get chrome from a can, but its very expensive and time consumeing.
http://www.kustomrides.com/home.php?cat=11
You ever get those security screws?
Post Number: 3133
BTW, Im gonna use Krylon paint, but its gonna be the chrome one, along with Krylon Primer, and Krylon Clear coat,
I'll see what I can do, If it doesn't look great, I can always paint over it with black, black covers everything
Username: Van_man
Boston South, MA
Post Number: 2482
I like Binz, or kilz for primer. Dries quick and covers well. Krylon is more of an automotive paint aint it? idk, I always use binz or kilz for primer. Good luck.
How bout brushing on some tar and rolling it in feathers? :-)
HD has some "plastic" diamond plate too. Just glue it on for a street tough look. :-)
Post Number: 3134
I think I'm gonna use kilz primer, I like it better, but as far as the chrome, it may not be Krylon, its something they have at walmart.
Username: Van_man
Boston South, MA
Post Number: 2484
nice.
Post Number: 3136
think its gonna be a negative on the chrome, I believe it would turn out silver, I'm probably gonna go with a greyish color to come close to the color of the interior of the trunk
Username: Mesodumm
Tri-City, Az Usa
Post Number: 140
have you seen the hammered metal grey by rustoleum
http://www.easy2diy.com/cm/easy/diy_dv_index.asp?page_id=35721700
Username: Th3pwn3r
Post Number:...
Post Number: 2874
^That says for METAL objects.Paints made for metal aren't the best for wood from my experience.
Username: Southernrebel
Post Number: 4983
wolfman,
If you paint the box...PLEASE pull the subs out before you start. :-)
Post Number: 3139
ha ha, I think I'm gonna leave it alone right now, I know its not that hard, just a bigger project than I want to get started right now, but yeah, I will pull them first....
Post Number: 3141
btw, what type of paint should I use on the box, I just figured that it has to stick to both the box and to the plastic port. latex paint?
