Bronze Member Username: Sound_questPost Number: 19 Registered: Apr-07 | can i get a few subs that are quailty sounding but are also loud |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2499 Registered: Dec-06 | What size are we looking at here? |
Gold Member Username: 420alldaylongPost Number: 1834 Registered: Sep-06 | Just to name a few. AudioQue.com Ficaraudio.com RDaudio.net DDaudio.com TC Sounds REaudio |
Gold Member Username: Adam_sPost Number: 1233 Registered: Aug-04 | Price range? |
Gold Member Username: Arande2Rattle your ... Missouri Post Number: 2500 Registered: Dec-06 | Aurasound.com |
Bronze Member Username: Sound_questPost Number: 20 Registered: Apr-07 | 12's |
Gold Member Username: 420alldaylongPost Number: 1836 Registered: Sep-06 | What amp are you using and what ohm is it stable at? |
Bronze Member Username: Sound_questPost Number: 21 Registered: Apr-07 | SONANCE SUBWOOFERS Sonance subwoofers have the ability to play hard at low tuning frequencies. Around here they are referred to as the 30hz Subwoofers. They are excellent in ported enclosures for street bass. These are great for Rap/Hip hop or for knocking stuff off people's walls as you drive past. Cast basket Resign spiders Integrated tinsel leads Non pressed paper pulp cone with Kevlar fibers Foam surround Long excursion motor structure 2" extreme temp voice coil 700 watts RMS Low carbon front and back plates Spider bolted down to basket Available in 10/12/15" Dual four ohm voice coils will this woofer be quailty |
Bronze Member Username: Sound_questPost Number: 22 Registered: Apr-07 | has any one had sonance |
Gold Member Username: 420alldaylongPost Number: 1837 Registered: Sep-06 | I don't think so RD is newer company but the people that have RD says it great email Kevin at Low Hz lowhz01@yahoo.com |
Bronze Member Username: DrummaIndianapolis, IN USA Post Number: 12 Registered: Jun-07 | Give us a price range and what amp you have, or how much rms your looking for. It will be more of a help for people trying to help you. |
Bronze Member Username: Sound_questPost Number: 23 Registered: Apr-07 | well i have a t5002 am 400-600 doller 1000rms to one sub or 500rms to 2 subs |
Bronze Member Username: DrummaIndianapolis, IN USA Post Number: 16 Registered: Jun-07 | Well, your amp is: 75 watts RMS x 2 at 4 ohms 150 watts RMS x 2 at 2 ohms 250 watts RMS x 2 at 1 ohm 300 watts RMS x 1 in bridged mode (at 4 ohms) 500 watts RMS x 1 in bridged mode (at 2 ohms) 1-ohm stable (2-ohm stable in bridged mode) So I would get 1 [2ohm] sub and bridge it. This amp wont give you 1000rms to 1 sub, it will only give you 500 rms to 1 sub, or 250 each to 2 subs. 2 channel doesnt mean you multiply the rms output of the amp by 2. Anyways here are some possibilities: 1x Alpine Type R [500 watts rms] 1x Audioque sd2.5 [500 watts rms] There are probably a lot more options, but if i were you and your budget for subs are 400-600, I would get a bigger amp, maybe the t1000bd, or a kicker kx1200.1, or an orion 2500d. Then you could get a killer setup for that much. Also, how is your charging system? Stock alt? Big 3? |
Gold Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 1413 Registered: Aug-05 | if you can get ur hands on the orion or t1000bd get it i have a t1000 n love it to death |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 867 Registered: Mar-06 | With that amp, a Rd Audio Classic or Sonance would be nice in 12 or 15 Kevin lowhz01@yahoo.com |
Gold Member Username: 420alldaylongPost Number: 1841 Registered: Sep-06 | thomas What did your birthsheet say power wise those amps are way underated. |
Gold Member Username: 420alldaylongPost Number: 1842 Registered: Sep-06 | thomas Rockford Fosgate Power Series T5002 Rated Power 75x2 at 4ohm stereo 150x2 at 2ohm stereo 250x2 at 1ohm stereo 500x1 at 2ohm bridged mono Average Actual Power 227x2 at 4ohm stereo 369x2 at 2ohm stereo 527x2 at 1ohm stereo 1054x1 at 2ohm bridged mono |
