Silver Member Username: PanamanianPanama cityPanama Post Number: 208 Registered: Aug-05 | I send my electric system in my car to be checked, the guy told me that 3 fuse were overpowered for the capacity, according to the diagram. 2 fuse had 15 instead of 10 and 1 had 30 instead of 10. However 2 days ago I feel my power (bass specificly) has decreased in about 30% to 40% I mean 2 days ago, because I didnt play until today very loud, and the bass was kinda weak. Could a fewer fuse cause that? was that 30amp fuse the one that was giving the power? Also, if for a stock headunit I use a 10amp fuse, and later want to change to 1200w (amplifier) do i have to modify it to about 30amp fuse? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2894 Registered: Jul-06 | DO NOT use a fuse larger than specified for your gauge of wire, and use the proper gauge of wire for your amp. Read here: http://www.bcae1.com/fuses.htm http://www.bcae1.com/wire.htm |
