Silver Member Username: Teamdeboy1971
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 492 Registered: Nov-06
Posted on I have found a good deal on a couple of MTX 9500's but they are single voice coil subs! Whats the pros and cons of a single voice coil?? Thanks |
Gold Member Username: Adam_s
Post Number: 1232 Registered: Aug-04
Posted on Dual voice coil allows for more options when wiring it up. Thats about it. |
Gold Member Username: 420alldaylong
Post Number: 1835 Registered: Sep-06
Posted on WIRING |
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 493 Registered: Nov-06
Posted on Thanks guys, I wasn't sure if it would effect the performance or not, so thanks!! |
Gold Member Username: Matt12490
California
Post Number: 2453 Registered: May-05
Posted on It does perfect performance.. just slightly, but you wouldn't notice anything by ear between a SVC and a DVC of the same sub. |
California
Post Number: 2454 Registered: May-05
Posted on ^Oh wait. I was thinking of between DVC 1 ohm vs. DVC 2 ohm subs. |
