Sub help
Username: 2007tchad
Csted, Virgin islands Vi
hi iam driving a 90 tercel 2door coupe looking for a high powered set and was wordering if i could have some ideas of what to do. iam not looking to go over $1500, and i don't use cheap quality stuff ? and iam planning to to do a full fiberglass trunk,or you can tell me what subs will sound coming out of my car?
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 7770
Is 1500 for everything or just for subs?
Username: 04redmach1
Columbus, GA USA
Post Number: 840
With a tercel, if you plan on 1000 rms or more you will HAVE to upgrade alt. Upgrade battery and you can prob go 1000 and be ok. Like Logan, is $1500 just subs or everything?
Kevin
Username: Nd4spd18
Southeast PA
Post Number: 2851
Yeah, have to keep it under 1000 watts or upgrade alternator, which will probably run about ~$500 right there.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 737
DD 9917 and memphis 4K along w/ upgraded alt and big 3
