Bronze Member Username: MrwebbPost Number: 51 Registered: Dec-06 | i am looking at a set of memphis 15's that are 250 rms and 500 watts peak and wanted to know am i setting up myself for disaster by putting my memphis 1000d mclass on them? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4654 Registered: Dec-05 | depends DVC config. You can always turn the gain down. |
Bronze Member Username: MrwebbPost Number: 52 Registered: Dec-06 | they are the memphis 15" pr series 4ohm dual voice..so would i need to wire them a certain way? |
Gold Member Username: 420alldaylongPost Number: 1813 Registered: Sep-06 | Wire them this way and keep the gain down and you will be fine. http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=2&impedance_of_subs=4o hm_dvc&x=126&y=12 I know of people that have had the same setup. |
