H/O Alternator for a 1994 Acura Legend.
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 736
I can't seem to find a bigger alternator for my acura, the only ones i find are the stock 110amp ones. I know it is a Honda motor, but am unfamiliar with alternators and stuff like that. Would say an accord H/O alt or Civic alt work for my acura? Or..
I just can't seem to find one.
Post Number: 737
WTF happened there? Posted 3 times? I didnt do it..
Post Number: 738
Thats where i looked and still no luck. Let me check again
Post Number: 739
ooh, I found one this time! how many amps should I look for. My stock one is 110amps and im running a kx1200.1. My lights dim at volume 8.
Username: Jblanford
Post Number: 1192
hmmh try
www.hoalternators.com
www.ohiogen.com
you'll probably have to email them and they will get back to you with quote's
btw they are fairly expensive but well worth the money
Username: Jblanford
Post Number: 1193
get the biggest you can get
link me to the one you found ?
Username: Jblanford
Post Number: 1194
also pay attention to idle amperage...
Post Number: 740
I cant go expensive =/
Do you think my alt is my problem if my lights dim at volume 8 on my kx1200.1. My battery died once due to my subs, but hasnt happened since, i put the gain down a little and continued playing at high volumes, but my lights still dim. Is this something I should be concerned about. Also, there is this local ma and pa shop that specifys in alternators, they rebuilt my friends. Is it possible if i take them mine (110a) they can 'rebuild' it and by doing so, make it say a 180a alt, or is this just impossible?
http://cgi.ebay.com/ebaymotors/180amp-Iraggi-Alternator-82-95-Honda-Acura_W0QQcm dZViewItemQQcategoryZ33573QQihZ019QQitemZ7959076285QQrdZ1QQsspagenameZWDVW
Idk what is good or bad for idle amperage. How does this look? but it is still a bit pricey. Keep in mind, my amp is only a kx1200.1.
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 7672
lol you want a bigger alt for running 1200 rms? If your lights dim at vol. 8 thats not right. Are you sure its 110a?
Post Number: 7673
I just think your alt is fucked if its making them dim at vol. 8 and made the battery die.
Username: Notoriousroc1
Post Number: 40
give db electric a call, they have really cheap prices...no first hand experience though
Post Number: 7679
www.excessiveamperage.com
Post Number: 741
yep. Sub controls are at +10/15 bass is +5/7, loud feature is on and there is an extra bump feature on the 9883 so where it pounds at 5-10.
Username: Nd4spd18
Southeast PA
Post Number: 2790
John, get this one:
http://cgi.ebay.com/ebaymotors/180amp-Iraggi-Alternator-82-95-Honda-Acura_W0QQcm dZViewItemQQcategoryZ33573QQihZ019QQitemZ7959076273
" also pay attention to idle amperage... "
X2 can't stress that enough
