Pioneer (AVHP4900DVD) Parking brake bypass??
Username: Matt87
i just got a Pioneer 6.5" In-Dash Mobile Video (AVHP4900DVD) and am trying to bypass the parking brake feature. I tried grounding it and it wouldnt work. What should i do to bypass the braking feature??
Username: Mikejones840
I just barely bought the same one and if you buy peripheral ptr7 universal trigger output module you can bypass it. Its pretty easy to install and it was only about 30 dollars. the only thing is you have to splice into you wires
Username: Matt87
yea i got some great information from someone else and just bought a switch from autozone for 4.99 and used that thanks for the info but this was alot cheaper and really easy
