Is this a good setup?
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 122
k i need to know if im just waisting my time or is this an ok cheap little setup that im gonna get. infinity 52.7i coaxial 2 way speakers, kicker 05ks693 3 way audio speaker(6x9), power acoustik NEO-40 car audio universal mount 220 watt tweeter pair. i really dont know what type or channel amp i need to run all this stuff but the most i will spend on what ever i get is like 300-400 and i need 6x9s, for the rear, 5 1/4" speakers for the front, tweeters, and an amp to run it all.
Username: Adddisorder
West palm, Florida
Post Number: 4454
i would sugggest not buying any of that. first off the speakers are coaxil which means they have a built in tweeter so you dont need more tweeters. and thos PA tweeters are crap.
if your set on those speakers and those sizes then get them and get an amp that does like 50-75rmsx4@4ohm
but really i would reccomend getting a nice 6.5 component set for only the front and leaving the back empty and putting them on a powerfull amp.
Username: Mmaudioconcepts
Murray, KY
Post Number: 268
no
Vista, Ca Usa
Post Number: 124
well how do i put a 6.5 into a 5 1/4" door spot and why cant i put more speakers in the back like another pair of 6.5's and what is a good pair/2 pair 6.5's and an amp to run them
West palm, Florida
Post Number: 4468
just make a wood baffel. and it should give you enough space.
and speakers in the back you can put some but there is no reason too.
Username: Ctmike
Ct.
Post Number: 4472
exactly^^ take the money you had planned on spending on rear speakers and add that to your budget for components.
for a cheap combo you can get a ed nine.2 and their lower end component set. it'll be about $302 shipped.
Vista, Ca Usa
Post Number: 130
o sweet! thats a pretty good price. now if i were to get that where would i find them and can you tell me how to build a wood baffel.
Vista, Ca Usa
Post Number: 131
would i need to run a amp through them?
Username: Ctmike
Ct.
Post Number: 4491
get it through www.edesignaudio.com in thier package builder. and the nine.2 is the amp. but i just saw your other thread, and if you want better components get with alter and get cdts'. they'll cost more but are worth it.
West palm, Florida
Post Number: 4472
just take a peice of MDF cut out a hole so the speaker will fit in it then mount it to your door over the stock location.
to keep things easy you can get the 5.25 but 6.5 will give you better bass.
Vista, Ca Usa
Post Number: 134
what if i already have 2 12" kicker comp vr subs un the trunk of my car. i really dont need more bass just more sound cuz right now its mostly bass
West palm, Florida
Post Number: 4476
well i mean like kick bass the 60-100hz area
