i have focal components in the front of my explorer, but sonys in the back, i definately want to upgrade from sony. I was looking at the JL XR 5x7 and infinity kappa 5x7. I have 2 15" subs so i dont really need bass, just highs. i can spend around $200. what would best 5x7 speakers be for highs?
I would go with Infinity Kappas. JL does make good stuff, but for the price diff, not woth it. IMO anyways. But be aware that you might notice the sound of the JL's more so than the INF though. They have a diff sound to them. Depends what you want, undistorded, smooth & natural yet balanced sound, or loud, crisp and clear, but not as balanced. IMO they both sound good, but I think Inf just sounds more natural and smoother than the JL's of the same class.. . . and cheaper too. But, that's not desireable to everyone.............
If the intent of the 15's are to be loud(duh), then you might just want to go with what will keep up. IMO the JL might get louder than INF. But truthfully, for 200 I would recommend you go with a comp set rather than coax. You would get a better buy. Just my 2 cents
Another thing. Most audiofiles would recommend that you use the coax as the rear fill. I beliave DLS makes some that are more or less made only for rear fill. It would be cheaper than 200.
I own an explorer as well - does your back door rattle? I dont think it is just my license plate.. id eventually like to dynamat everything.. but do you have that problem? The very bad trunk rattle?
