Cleaning up my install + new box :-)
Username: Southernrebel
Post Number: 4980
Been hand sanding this dam box for about 2 hours.
Got the Deka Intemidator batt in and the old install looked kinda messy w/ the batt and extra wire, so i HAD to do something :-)
4cuft net w/ external interchangable port...64sq inches. (Can you say 'low note' :-))
Still gotta make an SPL port for it, but that will come later (after i see how this box loads). Amps will be mounted under the port on my false floor...batt between the back wall of the truck and the port.
This will be ALOT cleaner than my last throw together box/install. Its smooth as a baby's bottom.
Pics soon.
Username: Oglejust
Post Number: 1745
hmm how low of a note? hehe
Username: Adam_s
Post Number: 1191
I had to do it.
Username: Oglejust
Post Number: 1750
^^^^ x2 lol
Username: Nd4spd18
Southeast PA
Post Number: 2812
X3
If it's Canaan's ya know its gonna be good.....
