New member Username: Solid8447Post Number: 2 Registered: May-07 | i was looking for a new sub and i've heard good reviews about the power acoustic MOFO so i wannted to know it one twelve of that would be enough for a small car. I was also looking at a 12 kicker crx Wats my better option and wats an amp that would power it thanks |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1116 Registered: May-06 | well first tell us your budget for sub/amp and how much power u got to use |
New member Username: Solid8447Post Number: 3 Registered: May-07 | 500 about give or take |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1117 Registered: May-06 | 500 for sub and amp? do u have wiring and HU? |
New member Username: Solid8447Post Number: 4 Registered: May-07 | i got like 500 for sub and amp but if i need more i'll just save up . i got a HU and the 500 is excuding wiring |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1119 Registered: May-06 | wat u looking for sq/sql/spl? and u just want 1 12? also what kinda car/alt? how much rms can u run safely? |
New member Username: Solid8447Post Number: 5 Registered: May-07 | im a noob wat is sq/sql/spl? also i have a mercury tracer. it just got a new alternator in it not sure about the details on it. if i have to i can get a capacitor if that would help |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1120 Registered: May-06 | nope caps are totally pointless w/o a HO alt and upgraded batterys, but anyway sq=sound quality spl=loudness sql= mix of both |
Platinum Member Username: Rovin2 10 Pioneer... Post Number: 11572 Registered: Jul-05 | ur budget may get u a dd 2512 & a hifonics amp .... |
New member Username: Solid8447Post Number: 6 Registered: May-07 | so wats my best option like what should i do would one twelve be enough |
Silver Member Username: TatonkaPost Number: 345 Registered: Mar-07 | $500 would get you a 15" Fi SSD with flatwind coil and a Hifonics 1206D amp. Yes, I had to name my setup lol. |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1121 Registered: May-06 | a tracer huh, anyway you could figure out alterntaor size, because id hate to tell you to put like 1000 or so rms on it, if u have a real small alternator |
Bronze Member Username: Slimdog53185Bowling Green, Kentucky U.S. Post Number: 30 Registered: May-07 | I have two 12 mofo's. They are pure spl. They don't sound that good but they are really loud. I haven't heard the kickers in years and I can't really remember what they were like. They have to sound better then the mofo. One 12 in a good box should be fine. You can get something better then both of those choices for $500. |
New member Username: Solid8447Post Number: 8 Registered: May-07 | i would rather get 12's wat would be good 12's |
Gold Member Username: Logan__tilleTeam Revolution Post Number: 7564 Registered: Feb-06 | I once used a 10" mofo to see how long it would last on a orion 2500D.. |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1122 Registered: May-06 | and............... lol |
Gold Member Username: Logan__tilleTeam Revolution Post Number: 7566 Registered: Feb-06 | 2 12" kikcer cvr's and a kicker zx750.1 or Hifonics 1206D 1 12 or 15" audioque SD2.5 on a kicker zx750.1 or Hifonics 1206D 1 12" or 15" FI SSD on a kicker zx750.1 or Hifonics 1206D www.audioque.com www.ficaraudio.com |
Gold Member Username: Logan__tilleTeam Revolution Post Number: 7567 Registered: Feb-06 | It lasted like 15 seconds. lol |
New member Username: Solid8447Post Number: 9 Registered: May-07 | i'll check my alternater size what am i lookin for on it i had 1000w rms running through it with my old system but then it got stolen and the sub never cut out .p.s. always make sure your doors are locked |
Gold Member Username: Logan__tilleTeam Revolution Post Number: 7570 Registered: Feb-06 | If your running 1200rms and under you should have no need for a new alt. |
Gold Member Username: CtmikeCt. Post Number: 4433 Registered: Feb-06 | laney, check your pms'. |
New member Username: Solid8447Post Number: 10 Registered: May-07 | how do you check pms ? its a stupid question but im not familier with this site format |
Gold Member Username: CtmikeCt. Post Number: 4434 Registered: Feb-06 | should go to your email address you used to register. alot of times it's messed up though. what's your email address, i'll send the message to that. |
Silver Member Username: J_c_wheeler8Columbus, IN United States Post Number: 655 Registered: May-06 | "If your running 1200rms and under you should have no need for a new alt." Logan Im pushing 1200rms on my Type R's and my lights were pretty much pulsating to the beat last night.. I think I need a new alt. |
Bronze Member Username: Solid8447Post Number: 11 Registered: May-07 | my email is lukelaney@gmail.com |
Bronze Member Username: Solid8447Post Number: 12 Registered: May-07 | i want some subs with deep clear bass not really going for loudness |
Gold Member Username: CtmikeCt. Post Number: 4455 Registered: Feb-06 | you get my email? i'm pretty sure kevin will hook you up with something that'll fit that. |
