Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 621 Registered: Jan-06 | I do have zx1000.1 & DD 2512 And My friend has zx750.1 and pair cvr's 12" 2ohm His system is louder than mine ?? Why . I have ported box . He has Saled . I want to buy 2 12" CVR's ? |
Gold Member Username: J_baby15DiRtY 5oUtH ... Post Number: 1830 Registered: Feb-06 | install...what kinda car is his in/what kind is urs in? Specs on ur box/his? |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 622 Registered: Jan-06 | Maybe Its the Car . He has Toyota Celica I have M-Benz E class (( HE HE )) But i installed his system in my car and its also Louder than my DD 2512 His Box ( 45"W . 15"H . 20"D ) Saled Mine ( 19" Port lenght (2.5port) 20W , 16H , 18D |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 13051 Registered: Oct-05 | 2 subs vs 1 one. not fair. |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 623 Registered: Jan-06 | how come Chad .. 2512 is rated @ 600w But its over 1000w cvr 400w And he has 750w AMP And i have 1000w AMP am ported , he is Saled |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 13055 Registered: Oct-05 | your friend has double the cone area with only 250wrms less than yours. not to mention the cvr's get loud. |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11549 Registered: Jul-05 | could be the box too since thats a world of difference ...... |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 627 Registered: Jan-06 | I know that chad . But that makes me ANGRE for that i want to get a pair of cvr's |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 13057 Registered: Oct-05 | no. i bet your subs sounds way better. you need to experiment with different boxes. like rovin said, it makes a world of difference. |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 628 Registered: Jan-06 | I don't know . But is it normal 2 cvr's to beat DD2512 EASLY |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 13059 Registered: Oct-05 | is it way louder than yours? if it is then its your box. your box isn't the right box for your car. how is it positioned in your car? |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 630 Registered: Jan-06 | and the cvr's sounds TIGHT . I like it . My sub's just moving . |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 631 Registered: Jan-06 | in the trunk and its faced to the outside . |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4392 Registered: Jan-06 | whats your box size and tuning? also ever consider adding another sub? |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 633 Registered: Jan-06 | 2.6cuft 35Hz Adding another 2512 would require changing my AMP. NAH i wont |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 13062 Registered: Oct-05 | what kinda port do you have? try a different box. like 3 cuft with 2 4" inch aeros tuned a bit higher than 35hz. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2758 Registered: Jul-06 | When you're playing your system is the trunk sealed off from the passenger compartment?You may need to port from your trunk into your vehicle because the sound and air flow is being way too muffled by the padding of the rear seat and possibly the rear deck. |
Gold Member Username: DrivingrecklessDD 9515f, 147.8 db Mov... Post Number: 3463 Registered: Apr-06 | at what ohm load does your amp put out 1000rms?? do you have it wired to that specific ohmload? could your sub not be gettin that power? whats your box tuned to? if its to high it wont be loud b/c most highly tune boxes arent loud to the ear, is your box prefab??? are your gains set correctly?? |
New member Username: ChemicalimbalancePost Number: 1 Registered: Sep-06 | try building the box like DD recomends. i have the same sub and a zx 750. its in a 2.75cuft tuned to 40hz and it gets really loud. i didnt beleive them either but after 3 boxes i do now. |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 635 Registered: Jan-06 | Prefab ?? what does this means @ 35Hz 500@4ohm 1000@2ohm Maybe ROB is right Cuz its not opened to the passenger compartment . So its wont loud But i did bring my box to the back seat . and its okay but still CVR"s Louder .. And i hate when my sub just moving , There are many airflow . U can hear the airflowing beside the Bass . chad . Would u explane 2 me more about ur box dimensions Thanks for all |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 636 Registered: Jan-06 | Okay Jeremy I would Do it again Whay is your Box Dimensions ? Maybe i will do it 3cuft - |
Gold Member Username: 420alldaylongPost Number: 1760 Registered: Sep-06 | 2.75cubes 40 square inch vent 16" long 40 Hz |
New member Username: ChemicalimbalancePost Number: 2 Registered: Sep-06 | my box is 28w x 13d x 14h thats internal deminsions. my port is about 44 square inch vent 16 inches long. these are the box sizes they recomend for one 12 and for me the 2.75 cuft worked the best. oh yeah its in a 97 toyota corolla. 1.75^ft (1) 12" 28.0 sq" vent x 16" long tunes to 40Hz 2.00^ft (1) 12" 32.0 sq" vent x 16" long tunes to 40Hz 2.25^ft r (1) 12" 36.0 sq" vent x 16" long tunes to 40Hz 2.50^ft (1) 12" 40.0 sq" vent x 16" long tunes to 40Hz 2.75^ft (1) 12" 44.0 sq" vent x 16" long tunes to 40Hz |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 638 Registered: Jan-06 | 40osq ?? how is that I did mine like this : 20W , 16H , 18D and the port lenght 19" port Width 2.5 ___ In yours what is the port Width ? 3" ? |
Bronze Member Username: Mack1989Post Number: 65 Registered: Mar-07 | Personally i find that any luxury car such as a benz or BMW do not get that loud. I have heard that the trunks are very tightly sealed off not allowing the sub to seem very loud inside the car. Also hes driving a celica which is a hatchback so theres nothing blocking his subs. Any sub in that car would seem louder then if it was sealed off in your trunk. |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 639 Registered: Jan-06 | thats right > But i put my Box inside the car > On the Back seat And its better but still not louder that 2 cvr's Thanks for sharing ur idea |
Bronze Member Username: Mack1989Post Number: 66 Registered: Mar-07 | ooops lol got lazy and decided not to read all the posts. |
New member Username: ChemicalimbalancePost Number: 3 Registered: Sep-06 | my port is just under 3.25 more like 3.2 inches wide x 14in tall. its actually 44.8 sq in. and its a COROLLA not a celica. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2617 Registered: Jul-06 | Sounds like your box is leaking a lot of air....... build a better box |
Silver Member Username: Night_mirageAmman, Jordan DDs dealer i... Post Number: 643 Registered: Jan-06 | thats what i 'm doing right now I'm trying 2.7cuft box I 'll tell u later .. Thanks |
Bronze Member Username: Imperial_designsLafayette, Louisiana Post Number: 88 Registered: Oct-06 | 1.75 tuned to 40 hz... that damn box is way to big....... give it about 35in^2 of port area... |
