Gold Member Username: Wolfman1966Http://www.realmofexcu..., See my KRAZY... USA Post Number: 3018 Registered: Jan-06 | Just wondering, can changing the LPF freq change how loud your subs sound? I moved mine up a bit earlier today, and it seems like they got louder. I used to turn the volume up all the way, and then when I really wnted them to hit, turn up the bass on the radio...NOW I can't turn up the volume more than 3/4 or then it sounds like it did before at full volume with the bass up, and IF I turn the Bass up all the way too, then the amp cuts out |
Gold Member Username: Wolfman1966Http://www.realmofexcu..., See my KRAZY... USA Post Number: 3019 Registered: Jan-06 | forgot to mention, this is still with the gain set barely above minimum |
Silver Member Username: Jesse59672OKLAHOMA Post Number: 402 Registered: Feb-07 | yes and no. maybe it just appears louder because the sub is picking up on more frequencies. or maybe the sub is picking up on less frequencies and thus hitting those tones harder. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2688 Registered: Jul-06 | Most people set that around 80-85 and it really shouldn't be past 100. |
Gold Member Username: Wolfman1966Http://www.realmofexcu..., See my KRAZY... USA Post Number: 3047 Registered: Jan-06 | got my answer already http://www.splbassx.com/forums/index.php?showtopic=10104 |
