Need your opinions please help
Username: Solid8447
i was looking for a new sub and i've heard good reviews about the power acoustic MOFO so i wannted to know it one twelve of that would be enough for a small car. I was also looking at a 12 kicker crx
Wats my better option and wats an amp that would power it
thanks
Username: Solid8447
Post Number: 7
i have 500ish wat are a good amp and sub combo
Username: Mmaudioconcepts
Murray, KY
Post Number: 220
the mofo is said to be power akustics pure spl sub. I know they get loud because ive heard them from a distance but i am not sure of there sound quality.as far as an amp the mofo wants 1200wrms @ 1ohm or @ 4ohm
kicker kx1200.1
or budget amp
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4199
Username: Slimdog53185
Bowling Green, Kentucky U.S.
Post Number: 31
Sound quality is not very good. I have two of them now. They are very much spl oriented. I'm only giving them 800w per sub, and they are LOUD. If loud is all you want then they do the job. You can still get something better for your budget though.
Murray, KY
Post Number: 243
bobby...i see that u r from Bg...i have two friends that are transfering to western...and i have a few friends that go there
Username: Nd4spd18
Southeast PA
Post Number: 2686
Power crapcoustic........ enough said.
