Need i deas for speakers
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 110
any good speakers that are not to expensive but can hit real good and make some noise.
Vista, Ca Usa
Post Number: 111
and they need to be 5.25" front and 6x9 in the rear
Username: Ctmike
Ct.
Post Number: 4361
by "not to expensive" exactly how much you talking about and are you looking for a component set for the front or just coaxs'?
Vista, Ca Usa
Post Number: 112
well im kinda a nood so what is the difference between them and which ones sound better amd are cheaper. around 100-200 at most. kinda on a limited budget cuz just spent $$ on prom and my job is only paying me 8 an hour + i only work 20 hours a week and gotta pay 25 a week 4 insurence
Username: Wrencher
Brighton, Illinois USA
Post Number: 40
I'd recomend in your case to just forget about the rear set and spend it on the front set. You don't really need rear speakers anyway. Are you going to be using an amp or just running it off the head unit?
Username: Salmiery
Martinsburg, WV
Post Number: 8
I have a similar setup - I would have access to a crappy 500 watt amp that is supposed to be 2 channel but for some reason i beleive it is a fake. I bought a sub/amp combo and the amp was a Patriot 2 channel 500 W amp that was bridged for the subs so i think it just says it is 2 channel when in fact its just a 1 channel.. I could use this for the speakers.. What would you suggest (under 150 per pair - just need mids/highs)
Vista, Ca Usa
Post Number: 125
ya im gonna us an amp. what type of speaker is better for a daily driver and can get loud when turned up?
