Bronze Member Username: EzstuffNeenah, Wisconsin United States Post Number: 11 Registered: Jan-07 | ok well i was pretty content with buyin a fi q but today i went into a car audio shop and the guy has a pair of 10" idmax for 180 each. so what do you think i should do? should i go and get the id max's or stick with the q? if i stick with the q should i get 2 12's or a 15? thanks |
Silver Member Username: Skibum12189Cleveland Post Number: 608 Registered: Mar-06 | 2 12" Q's for sure |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1326 Registered: Dec-06 | x2 |
Bronze Member Username: EzstuffNeenah, Wisconsin United States Post Number: 12 Registered: Jan-07 | ok sweet thanks, what amp would you recommend getting to run them? |
Silver Member Username: MmaudioconceptsMurray, KY Post Number: 153 Registered: Jan-07 | mm2000.1D http://ikesound.com/product-product_id/6039 |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 753 Registered: Aug-05 | RD Audio 1750.1 |
Gold Member Username: Logan__tilleTeam Revolution Post Number: 7505 Registered: Feb-06 | I would rather have the Idmax's |
Gold Member Username: CtmikeCt. Post Number: 4415 Registered: Feb-06 | idmaxs. especially new for $180 each, that's a steal. |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1496 Registered: Dec-06 | I would take the ID's for that price too |
Bronze Member Username: EzstuffNeenah, Wisconsin United States Post Number: 13 Registered: Jan-07 | how do the idmaxs compare with other stuff? are they good sql? |
Gold Member Username: CenusHicksville, Ohio Post Number: 3191 Registered: Jan-05 | idmaxs are considered by most to be one of the best sq subs ever made, there get fairly loud also, they only need about 700wrms anything over 1000 is overkill. i'd defiantly take the ID's over fi anyday. |
Bronze Member Username: EzstuffNeenah, Wisconsin United States Post Number: 14 Registered: Jan-07 | awesome, well im gonna pick them up tomorrow once i get my check then, thanks guys |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1515 Registered: Dec-06 | You will be blown away with those subs. |
Silver Member Username: Jesse59672OKLAHOMA Post Number: 399 Registered: Feb-07 | "You will be blown away with those subs." killa has the same effect, and you can get him for much cheaper |
Gold Member Username: BernymacCambodian Post Number: 2805 Registered: Sep-04 | ID MAX! |
