New member Username: CbellPost Number: 1 Registered: May-07 | First post on ecoustics, I plan on buying a pair of Klipsch F-2 floorstanding speakers and a Yamaha RX-V461 reciever. With wires I plan on spending around 1100 dollars. This is a build up so center surround and woofer will be purchased but currently trying to get the base. Is this setup worth the money and what other brands might achieve the same quality. Reciever http://www.crutchfield.com/S-jXUS40vUbhL/cgi-bin/ProdView.asp?g=10420&I=022RXV46 1 Speakers http://www.klipsch.com/products/details/f-2.aspx Inclosed room 15/15/8 w/l/h |
Silver Member Username: MccambleyBREEZY POINT, NY USA Post Number: 362 Registered: Jun-05 | I am not a Yamaha fan,in my opion Denon would be a better choice, with Paradigm speakers. http://usa.denon.com/ProductDetails/3255.asp http://www.paradigm.com/en/paradigm/fronts-monitor-minimonitor-model-2-4-1-14.pa radigm |
Silver Member Username: Eib_nationOhio EIBville Post Number: 186 Registered: Jul-06 | Clarke, Yes, that would make a good beginning to any system. My only suggestion is to do a dealer search, and strive to get a pair from the Reference line if at all possible. http://www.klipsch.com/products/details/rf-62.aspx The F-2's are a good value for the $$$, but if you like those, you'll really like the RF-62's. The RF-62's are similar in design, except with a higher build quality. |
