Bronze Member Username: Snowblindace
Harrodsburg,
Ky
Post Number: 45 Registered: Apr-06
Posted on Ok what load does a dual 1 ohm sub wire into cause i am looking at the Fi Q i just need an idea of what i am going to need. |
Gold Member Username: Adam_s
15 TC9 Hybrid,
RE MT Softparts
Post Number: 1155 Registered: Aug-04
Posted on Dual one can be wired to .5 ohms or 2 ohms. |
Silver Member Username: Goodie_goop
Midland,
Texas
U.S.
Post Number: 586 Registered: Oct-06
Posted on for one sub it wires to 2ohm or 8ohm...or even .5ohm dual 2 would wire to 1ohm or 4ohm |
15 TC9 Hybrid,
RE MT Softparts
Post Number: 1156 Registered: Aug-04
Posted on There is no way you can wire a dual one sub to 8 ohm. |
Harrodsburg,
Ky
Post Number: 46 Registered: Apr-06
Posted on ok thanks for you help. |
Silver Member Username: Blkwardog
Adel,
Iowa
Usa
Post Number: 143 Registered: Mar-06
Posted on alrite so wut all could a single sub in 2ohmdvc wire to? im lookn to get an ssd and they only hav 1 and 2 ohm dvc's |
15 TC9 Hybrid,
RE MT Softparts
Post Number: 1159 Registered: Aug-04
Posted on One sub DVC 2 ohm can be wired to 1 ohm or 4 ohm. |
Adel,
Iowa
Usa
Post Number: 144 Registered: Mar-06
Posted on alrite thanks thats wut i was thinkn jus thought id make sure |
