Help!!!
Username: Holt_champ
Htown, MI
Post Number: 775
would i need an amp for some 6.5 speakers or can i just connect them to the factory wiring that was used for my stock speakers? if so what are some good amp/speaker combinations??
Username: Dakangofkrunk16
Post Number: 262
You can but it wont sound as good... Most likely there isn't a good Xover on your Stock HU.. Which can lead to to much bass or bass on the tweets and blah blah
Just look at a speaker, look at specs and go from there for an amp
Ex.
6.5
Load 4
Rms 100
Amp
load 4
Rms 85-100 will sound good
Make sure your get a 4 channel amp.. with a high pass filter and a cross over for it to set the tweets to get the highs and the lows to go to the sub part
Htown, MI
Post Number: 776
what is a good speaker?
Post Number: 263
One that works ha ha jk
Adire Audio
Alpine (F1 Status components)
Arc Audio
Beyma
Boston Acoustics
Bravox (component sets)
CD Technologies (CDT)
Diamond Audio
DLS
Dyn Audio
Eclipse
Focal
HI-VI Research
Illusion Audio
Image Dynamics
Infinity (Kappa Perfect series)
JL Audio (XR components)
JL ZR component line
LPG
Max-Fidelity
MB Quart
Morel
Rainbow
Resonant Engineering
Scan-Speak
Seas
Vifa
Visatron
https://www.ecoustics.com/electronics/products/articles/329117.html FTW
Htown, MI
Post Number: 777
ok thanks alot
