Cutting wood?
Username: Fatkid
tonawada, Ny
Post Number: 227
what is the best way to cut wood straight with a circular saw?
Username: Th3pwn3r
Post Number:...
Post Number: 2747
Well...the best way would be to probably cut a tiny bit big and then fine tune your cut.Better to cut too big than too small.You should really get a table saw or have someone else cut it though,it's kind of hard to get a straight cut with a circular saw but it can be done.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1828
2 C-clamps and a straight edge....perfect cuts. Set up the straight edge kinda like the fence on a table saw...clamp it down, and follow the straight edge w/ the circular saw.
Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1562
"2 C-clamps and a straight edge....perfect cuts."
yup.
Username: Fatkid
tonawada, Ny
Post Number: 228
ok thanks
A pic is worth 1000 posts!!
Post Number: 6702
Buy a panel saw. Only $1200 or so.
