Silver Member Username: BasssquaredKansas Post Number: 423 Registered: Nov-06 | does anyone know anywhere i can get an amp that does 1500 watts at 1 ohm and has warranty for 400 dollars shipped? |
Bronze Member Username: ShorterthanrichPost Number: 38 Registered: Apr-06 | Talk to Kevin Holden. He can probably do something good for you on a Sundown. |
Bronze Member Username: ShorterthanrichPost Number: 39 Registered: Apr-06 | Here's his email. lowhz01@yahoo.com |
Silver Member Username: BasssquaredKansas Post Number: 424 Registered: Nov-06 | Thanks Rich |
Bronze Member Username: ShorterthanrichPost Number: 40 Registered: Apr-06 | No problem! |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 601 Registered: Nov-05 | lol MS just advised u the same thing! fast learner. I like you rich i like you a lot. |
Bronze Member Username: ShorterthanrichPost Number: 43 Registered: Apr-06 | Hahaha, thanks JK. I appreciate everyones help a lot, particularly Kevin's, so I should pass it along. Also I've been reading these forums obsessively and feel that I MUST respond to any post I can. So much information. Can't break addiction. ::twitch:: |
Gold Member Username: LoudonPost Number: 1102 Registered: Jun-04 | no way ur getting a sundown for 400 bucks lol massive 1500 is more in ur price range |
Bronze Member Username: ShorterthanrichPost Number: 64 Registered: Apr-06 | I was gonna get a sundown SAD 1000D for $285. I'd imagine a 1500 watt would be somewhere <$500. You will probably have better luck with the massive, though. Thanks Mike. |
Bronze Member Username: ShorterthanrichPost Number: 65 Registered: Apr-06 | I was gonna get a sundown SAE 1000D for $285. I'd imagine a 1500 watt would be somewhere <$500. You will probably have better luck with the massive, though. Thanks Mike. |
Gold Member Username: 420alldaylongPost Number: 1744 Registered: Sep-06 | SAE1000D = $325 14.4 volts SAZ1500D = $450 12.8 volts |
Silver Member Username: BasssquaredKansas Post Number: 432 Registered: Nov-06 | so how much does build quality have to do with things because a hifonics amp that puts out 1600 watts at 1 ohm for under 300 shipped i know it wont give out the rated 1600 but close to 1500 im assuming at a way lower price so i was wondering if the extra build quality was worth paying for? |
Bronze Member Username: ShorterthanrichPost Number: 70 Registered: Apr-06 | I say yes. Make sure that hifonics is 1600 watts rms. As far as I know its not just build quality, its sound quality. but thats just in my opinion from what i've gathered, not personal experience |
Silver Member Username: BasssquaredKansas Post Number: 433 Registered: Nov-06 | but im not worried about SQ i just care about SPL |
Silver Member Username: KillswitchjdPost Number: 608 Registered: Apr-06 | get the ed nine.1 for 365 plus 10 % off if you call and ask. should be about 1400 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4626 Registered: Dec-05 | autotek mm1400.1 should work for you |
Silver Member Username: BasssquaredKansas Post Number: 437 Registered: Nov-06 | whats the price on that autotek? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2577 Registered: Jul-06 | Amplifiers are transparent in terms of SQ. It is build quality that separates them. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1316 Registered: Mar-04 | The Lanzar opti2000d is ~1600w rms @ 1, and will do 1900+ at 1/2. $370 shipped from onlinecarstereo.com with a 1 yr warranty. |
Silver Member Username: KillswitchjdPost Number: 609 Registered: Apr-06 | lanzar is a joke of a brand. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2597 Registered: Jul-06 | ^^^^ the Opti series isn't. It is well worth it to get something like a Sundown over a hifonics or Lanzar though. If you buy a budget brand, you can't expect it to last a real long time. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1317 Registered: Mar-04 | "lanzar is a joke of a brand." you're a joke of a contributor. |
Gold Member Username: 420alldaylongPost Number: 1750 Registered: Sep-06 | Kicker KX1200.1 DEI Directed D2400D Phoenix Gold RSd1200.1 JBL GTO1201.1 Memphis MCD1500.1 Orion HCCA D2400 Rockford T10001bd MTX TA81001 |
Silver Member Username: BasssquaredKansas Post Number: 439 Registered: Nov-06 | Well thanks for all your guys suggestions i guess i have lots to chose from well right now im looking at more of a budget amp and its cool that it wont last long im not expecting it too im getting a job this summer and with that money i want to get hopefully get a ZX 2500.1 hooked up to four 12" 4 ohm L7s but until then i just need an amp to push my 2 12" 4 ohm L7s so i think its between the hifonics and the Lanzar |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1318 Registered: Mar-04 | I have nothing against Hifonics, I recommend them a lot - for the price I think they are solid sub amps. However, I believe in terms of durability, actual power vs. ratings, longevity, versatility (ability) to go down to 1/2 ohm -- The optidrive is the better amp in all categories. I've also dealt with Lanzar's CS on a couple of occasions and been satisfied both times. |
Gold Member Username: 420alldaylongPost Number: 1754 Registered: Sep-06 | Budget amp http://www.millionbuy.com/powasa15001d.html |
Silver Member Username: BasssquaredKansas Post Number: 440 Registered: Nov-06 | yeah my local dealer was trying to sell me that amp for 550 dollars ok im definately not going to buy that from him that amp does look pretty good specially for that price thanks a lot Joey so do these amps do close to rated power? |
Gold Member Username: 420alldaylongPost Number: 1759 Registered: Sep-06 | raymond aparicio Around 1200-1250 watts What subs are you going to be using? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4631 Registered: Dec-05 | i'd pick optidrive. IT did 1400w rms at 12V. 1 ohm. You can get it on ebay too and get a better deal. Onlinecarstereo is great too. |
Silver Member Username: BasssquaredKansas Post Number: 444 Registered: Nov-06 | Joey --- "until then i just need an amp to push my 2 12" 4 ohm L7s" and thanks Julio B well they both look like pretty solid amps im leaning towards the optidrive but i guess im just going to go with wichever i can find cheaper well thanks for all the help and 1400 watts should do the trick |
Silver Member Username: BasssquaredKansas Post Number: 445 Registered: Nov-06 | ok sorry im confused Juliob can you tell me what model amp are you talking about its a lanzar opitidrive but wich one? sorry for the confusion |
Silver Member Username: DenimWww.TeamSSAudio.com, MD Post Number: 268 Registered: Nov-06 | US Amps XT4000D? http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=28 |
Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 3012 Registered: Mar-06 | http://cgi.ebay.com/US-AMPS-4000-WATT-AMP-AMPLIFIER-XT4000D-XT-4000-D-MONO_W0QQi temZ330123209999QQihZ014QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I think it comes with man. warranty... it says it at the bottom but i dont see it in item description.. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4632 Registered: Dec-05 | lanzar optidrive 2000D. |
Silver Member Username: BasssquaredKansas Post Number: 448 Registered: Nov-06 | well theres definately too many choices so its between the hifonics BX2000, the Lanzar optidrive and now possibly this U.S amps amplifier well this is really going to be a tough choice |
Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 3018 Registered: Mar-06 | if your looking for quality the us amps takes it |
