Silver Member Username: BasssquaredKansas Post Number: 441 Registered: Nov-06 | im in the process of making a box for my 2 12" L7s well i was going to get fisher customs to do it for me but i allready have some 3/4 inch MDF wood laying around about 3 sheets so i thought i would give it a try first and if it doesn't work out then have them do it but im using subwoofertools.com to make my box plan but i need the subwoofer displacement for a 12" L7 i looked on kickers website and found it only in cc and i dont even know what that means so if anyone could help me i would greatly appreciate it |
Silver Member Username: BasssquaredKansas Post Number: 443 Registered: Nov-06 | looks like its hard to get help at 2 am in the morning |
Silver Member Username: BasssquaredKansas Post Number: 446 Registered: Nov-06 | Anyone |
Gold Member Username: J_baby15DiRtY 5oUtH ... Post Number: 1853 Registered: Feb-06 | cc = cubic centimeters, thers converters online thatll convert that to cubic foot or cubic inches for ya jus google for metric conversion. |
Bronze Member Username: MesodummTri-City, Az Usa Post Number: 75 Registered: Apr-07 | Hey Raymond, I saw you post at about 12am this morning, your what 3 hours ahead of us. Here is the link to kicker this one gets your manual in PDF format. http://www.kicker.com/06/kicker_home.html this site is in Flash, Enter site, go to upport, then Technical Support, look up your sub then you have your specs. You will need to pick 2 ohm or 4 ohm then you can go to a couple of differant sights to help figure out building your box. http://www.mhsoft.nl/spk_calc.asp http://www.carstereo.com/help2/Articles.cfm?id=31 Hope that helps you! |
Silver Member Username: ReppinqcCharlotte, NC USA Post Number: 514 Registered: Jan-07 | sorry for OT but is this a really shi++y box for 2 15" L7's cause this is what i have and would it hit a lot harder with a custom made box? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3781 |
Bronze Member Username: MesodummTri-City, Az Usa Post Number: 77 Registered: Apr-07 | In description it doesn't say whether it is made to spec for your sub. So I would say no when you download your manual you will see what the manufacturer recommends. These companies spend Millions in there R&D departments, testing and pushing there subs till they blow up or they work to perfection. stay with there specs espeacially if your new to box building! You can build your box for a heck of a lot cheaper than buying that $179 + tax&shipping. Besides you have 3 sheets of 3/4 MDF already. If you need any help I will do what ever I can for you. There are alot of experienced builder on this site, Who have years and years of knowledge which will be to your advantage when asking questions. Thanks |
Silver Member Username: BasssquaredKansas Post Number: 447 Registered: Nov-06 | well thanks a lot guy so just to double check does this look correct for 2 12" dual 4 ohm L7s http://www.subwoofertools.com/forum/ported-box.asp?Ew=36&Eh=13&Dia=7&Xmax=14.1&V d=0.087384+&NumW=2&Vb=4&Fb=38&Qts=&Vas=&Fs=&CE=0 |
Bronze Member Username: MesodummTri-City, Az Usa Post Number: 78 Registered: Apr-07 | "well thanks a lot guy" I wasn't trying to be a jerk or anything hope you didn't take it that way, What is the model number of your subs? and what do you want it tuned at? Are you building Custom box or just square box?? The box above would work as long as you go off of sub specs. Very Important!! Let me know! Thanks |
Silver Member Username: BasssquaredKansas Post Number: 450 Registered: Nov-06 | lol no im not upset at all this is funny i dont know why whenever i try to be polite people think im upset lol oh and i meant to put guys not singling you out MSD lol but really thanks for your guys' help and they are 2 12" L7s dual 4 ohm and im trying to make the biggest box that can fit in my jetta the height of the trunk is 13" its 36" wide and 36 inches" long oh and i want to tune it to 38 hertz |
Silver Member Username: BasssquaredKansas Post Number: 451 Registered: Nov-06 | so does that look good to everyone before start building? |
