Bronze Member Username: ArmstrongPost Number: 20 Registered: May-07 | hey, what's a good 2 channel amp that puts out 80-100 rms at 4 ohms? my budget is $150. it is gonna be used to power a set of phoenix gold rsd6.5 comps. i've looked on ebay and i've found these amps... are any of these good or are there others you guys could recommend? JL e2150 Rockford Fosgate P325.2 MTX TC3002 Kicker Kx250.2 |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2546 Registered: Jul-06 | The Kicker is the best out of those. Kicker amps are good quality. |
Bronze Member Username: ArmstrongPost Number: 21 Registered: May-07 | anybody else have any input? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4621 Registered: Dec-05 | nick, i'm going to buy those components, so when you get it give me a PM with your opinion. Rockford, kicker,jl they're all good choices |
Bronze Member Username: ArmstrongPost Number: 22 Registered: May-07 | anyone else? |
Silver Member Username: DenimWww.TeamSSAudio.com, MD Post Number: 266 Registered: Nov-06 | The Kicker is nice, could do a Rockford P200.2 http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=109 |
Bronze Member Username: ArmstrongPost Number: 23 Registered: May-07 | yea, i'm pretty much trying to choose between the jl, kicker, or rockford. it's a tough choice. since they're all known to make good amps, would i really even notice much of a difference between them? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4634 Registered: Dec-05 | no. Maybe in durability. I'd pick kicker IMO. |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 794 Registered: Mar-06 | I can give you a good deal on a Massive Audio P200.2 or Cadence FXA2100. Both do 100x2 @ 4 ohms. Kevin lowhz01@yahoo.com |
