Help with hooking up
Username: Bluepopcicle
Post Number: 9
hey, i just got my fi ssd 12inch 2 ohm. i'm wondering how i wire it up so its a 2 ohm load?
Username: Quig
PgH, PA US
Post Number: 579
if its dual 2 ohm... ur screwed u can either wire it to 1 ohm or 4 ohmn
Username: Insearchofbass
Post Number: 5120
is that a single voice coil?
Los Angeles, CA USA
Post Number: 13086
you can't unless you have 2 subs. if you have 2 subs then you can wire it series-parallel to see a 2ohm load.
if only one sub then you can either have 4ohm or 1ohm load.
Los Angeles, CA USA
Post Number: 13087
where did the thread go?
Post Number: 5121
if your amp is stable at 2 ohms in stereo that would be a fix but then you would need something to filter out unwanted frequencies
