Box design.
Username: Trey4sports
Post Number: 1226
when i port my box's i like to use PSP ports because there easy, AND flared. but my question is do you think it would optimize airflow if i rounded the internal corners of the box and filled about an inch thick with caulking and some time of wood. instead of having the squared (internal) 90 degree corners?
Username: Jkidder
Spring hill, Florida Usa
Post Number: 651
rounded the inside corners? like with caulk or with wood? im not sure wat ur saying
Post Number: 1228
do caulking, and then maybe wood on top?? not sure jsut tryin to figure out if that would help
Username: Bernymac
Cambodian
Post Number: 2770
why caulk it and then put wood on top of it? Just glue the wood onto that corner. It will create better air flow within the box, as for outside? I'm not sure.
Post Number: 1232
ok gotcha, so i will just glue some rounded corner wood into the corners
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 2954
dont use to much caulk or it will take a long a55 time to dry, but after putting the wood in smooth caulk over it to fill the gaps
Username: Mesodumm
Tri-City, Az Usa
Post Number: 70
I have always routed the edges of ports 1/4 in side and 1/2 outside with 1/8 inset that makes the carpet lay real nice! if you ad the rounded wood it still would ad length to your port and if ever comes off could kill you sub!
