After doing an Autoscan, all the channel labels have changed, example. Before when using the channel guide It would say something like Fox|Washington now In order for me to find my local channel I would have to go to WTTG?
Did I scan wrong or something? I scanned echostar 6, 8 an echo 7 which is 119 and 110 ???
Probably what you had before was a customized channel list where you can name the channels as you want, at the time you did the autoscan it overwrited whatever you had regarding that channel list and those names are the ones that come with the signal from the sat.
The only thing you can do to get the names back again is name the channels one by one or get the customized list and download it to the receiver using channel master or any other of the programs that exist to do that.
Also you can ask the guy who sold you the receiver to download the list again but that will cost you some bucks.
