Treo SSX750.1
Username: Boomtank
Rochester, NY USA
Post Number: 241
Anyone know any stats on this amp. all i know is from ampguts...
375 @ 4ohm
750 @ 2ohm
is this at 12.5, 14.4, 17 volts?
anyone know if its 1 ohm stable?
THD or dampining factor?
Username: Basshead86
FTW
Post Number: 9977
it will do 1500 at one ohm.
or so i am told and have read:-)
FTW
Post Number: 9978
they are solid amps. i almost bought one but ended up getting a DLS A6. it was better for my application. i am not certain but check the website for stats. i used to have a booklet that hat them, but i threw it away.
Username: Ctmike
Ct.
Post Number: 4382
what's up muddy?
the only thing i've found on that amp is some people said they are rated at 17v and it's rated at 1300wrms at 1ohm.
Username: Boomtank
Rochester, NY USA
Post Number: 242
Sweet, Ill be testing it out this weekend. How do you measure the acuall power output?
Username: Killswitchjd
Post Number: 593
you bench test it somewhere
Username: Boomtank
Rochester, NY USA
Post Number: 245
im problably gonna bench test it myself, i just wanna see how it compares to my other amps.
Username: Ctmike
Ct.
Post Number: 4390
you have the equipment for benching amps? you own a shop or something, knows someone that does you use for free?
Username: Boomtank
Rochester, NY USA
Post Number: 249
me aand my buddy have an install shop.
