Username: Rds2oo8 MN
Post Number: 120 Registered: Nov-06
Saturday, May 19, 2007 - 15:11 GMT for a daily driver use and what FI or DD should i get?
Username: Mike11202 DE
US
Post Number: 595 Registered: Nov-06
Saturday, May 19, 2007 - 15:14 GMT are you more on SQ or SQL?
Username: Nyyfan13 Fi SSD
Post Number: 5117 Registered: Jul-06
Saturday, May 19, 2007 - 15:18 GMT budget as well
Username: Loudon Post Number: 1100 Registered: Jun-04
Saturday, May 19, 2007 - 15:21 GMT use the search button pal this thread has been made 75000 times comparining the two theres no better or worse its what applies to ur budget ... which im guessing is FI cuz most people arent gonna dish out the money it costs for a DD woofer . for someone who doesnt have much expierience a FI ssd with a kicker zx750.1 if your system hands down ... 3.0 cu ft box tuned to 32 hz ... end of story no electrical upgrades, no need for an HO alt, your all done end thread/
Post Number: 122 Registered: Nov-06
Saturday, May 19, 2007 - 15:25 GMT SQ n im in the works for getting the money right now to buy a system im thinkin like 3 grand i drive an 02 lesabre
US
Post Number: 597 Registered: Nov-06
Saturday, May 19, 2007 - 15:33 GMT If he wants SQ go witht the Fi Q... how much room do you have?
Post Number: 123 Registered: Nov-06
Saturday, May 19, 2007 - 15:40 GMT um the trunk is 58" by 48" n then 16 tall my friend says i could prolly fit 3 12s in the smaller section n 2 15s in the bigger part but ill prolly just do 2 12s with all the airspace left in the trunk itll bump alot
US
Post Number: 598 Registered: Nov-06
Saturday, May 19, 2007 - 15:41 GMT never mix sub sizes..
Post Number: 125 Registered: Nov-06
Saturday, May 19, 2007 - 15:45 GMT yeah thats what alota people on here told me so yeah ill just sit wit 2 12s n an amp so 2 12's FI BL's what kinda amp? what HU would u recomend for 300 or under
Post Number: 126 Registered: Nov-06
Saturday, May 19, 2007 - 15:47 GMT so 2 12" BLS wit what kinda amp? would i have 2 upgrade the charging system and stuff? what HU would u recomend for 300 or under
Post Number: 127 Registered: Nov-06
Saturday, May 19, 2007 - 15:54 GMT bump
Username: cam Post Number: 368 Registered: Nov-06
Saturday, May 19, 2007 - 15:56 GMT usually you do a ho alt at 1kw. but you gotta hook it up n check your voltage drop and headlight dimming to know for sure.
Username: Killswitchjd Post Number: 602 Registered: Apr-06
Saturday, May 19, 2007 - 16:00 GMT if you are running two bl's then you need a high output alternator. 2000 watts.... a nice hu under 300 would be alpine, eclipse, probably a few others
Post Number: 128 Registered: Nov-06
Saturday, May 19, 2007 - 16:11 GMT how do i find out how much my stock ALT runs? lol
US
Post Number: 599 Registered: Nov-06
Saturday, May 19, 2007 - 16:17 GMT why BL's? the Q's are Fi's SQ sub.. BL is a bit more spl oriented
Post Number: 129 Registered: Nov-06
Saturday, May 19, 2007 - 16:22 GMT oic so 2 FI Q's then they both cost teh same
Username: Jkidder Spring hill,
Florida
Usa
Post Number: 607 Registered: Nov-05
Saturday, May 19, 2007 - 21:53 GMT u have 3 grand? buy 1 DD 9917 and power it with a memphis 4k along with 2 kintetik hc2400's and a nice 5-7cube box tuned to 32
Florida
Usa
Post Number: 608 Registered: Nov-05
Saturday, May 19, 2007 - 21:53 GMT o and a ho alt. no lower than 250 amp
