New member Username: DdukestermanPost Number: 1 Registered: May-07 | From the battery to the amp, how many volts would the fuse have that goes in between the battery and the amp?? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2543 Registered: Jul-06 | Fuses are rated in amps not volts, and the fuse size depends on the wire gauge. Wire Gauge .... Maximum Fuse Size 00 awg 400 amps 0 awg 325 amps 1 awg 250 amps 2 awg 200 amps 4 awg 125 amps 6 awg 80 amps 8 awg 50 amps 10 awg 30 amps 12 awg 20 amps 14 awg 15 amps 16 awg 7.5 amps Credit: www.bcae1.com/fuses.htm |
