Help Me Guys
Username: Dakangofkrunk16
Post Number: 188
Ok i got a pioneer deh 780...The screen is blank everything works except the screen ...it just started to do this... had it installed for a while now..i'm hopping a wire just came out any suggestins
Username: Logan__tille
Los Angeles, CA USA
Post Number: 7331
Blow out that little clip things the make the HU and the Screen attach. Or Maybe push in on the screen a little.
Username: Bernymac
Cambodian
Post Number: 2725
^yep, and if thats the problem, you can order that piece on pioneers website instead of ordering a new face all together.
Post Number: 189
I did that all a gave it a nice blow job...and then tried pushing it in...it lites up blue all together..but no screen, you think it is the face plate or the HU it self
My plan was to go to BB and swap the faceplate they have on display with mine, but they took the 780 deh down
Post Number: 190
Any one that helps me out...i'll have Chad blow you, all he has to do is pretend your an amp...cause he knows how to do that lol
CHAD I'm Kiddin....I'm Just aPost Whore lol
Username: Th3pwn3r
Post Number:...
Post Number: 2634
You can try cleaning the contacts.
