What else
Username: Kaprese
Walstonburg, NC USA
Post Number: 155
Alright I have a SVC 4 ohm Solobaric S15D in a 1.5cu sealed enclosure,a Kenwood KAC-8101D mono (200w at 4ohms and 400w at 2ohms)and a Panasonic 8300u with eq,crossover,sub-out,etc.I drive a Saturn SL2 1998 with fold down seats and took out rearfill.
Tuning- My amp gain is set I have the lpf at 70 and dynamic expander on (amp).NO bassboost no loud button
Q-What else could I do to improve my system as it is now? I have little money to uprade so what are so tips and Tricks you guys used to improve you system in anyway ?
Username: Kaprese
Walstonburg, NC USA
Post Number: 158
all out of idea's
Username: Bernymac
Cambodian
Post Number: 2727
Best advice, save your money =). btw, how much money do you have saved.
Username: Nd4spd18
Southeast PA
Post Number: 2466
Really the only way to get a "free" increase in loudness is to play with the box positioning......
Username: Joebruce
15 Inch Wang...
Post Number: 888
Yea i would save some money and get new evrything. Im not sure what the rms on that sub is but your only giving it about 100-150 wrms,if that. The cheapest and best thing you could do with the stuff you have now is build a ported box,that would give you more output.
Username: Kaprese
Walstonburg, NC USA
Post Number: 160
I have like 150 saved up and for that Solobaric S15D it is suppose to be in a sealed enclosure but could I still port it and see how it sounds and how should I port it ?
