which is pretty much, all the power it needs. RMS on that sub is probaly 350rms? 200rms should do it fine. If you want a better amp, a kicker 750.1 would be good, but it will also do close to 1000rms and might fu*k your subs up. So, connect them, see how they perform, and if 400rms total output is all you need, then thats all you need. Should sound nice.
