Alpine or Kicker?
Username: Aman2005
Patiala, Punjab India
Post Number: 423
Hi,
my setup plan screwed up because of some personal problems.
Now I am getting up a bit confused in choosing a sub. I wam confused betwenn Alpine type R and Kicker CVR12 D4.
What you guys say, which one should be good in term of life and sound? I need loudness but with a clear sound. IT hink its called SPL, isnt it?
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 567
I had 2 CVR's and I hated them. I upgraded to Alpine Type R's (2 of them) and they slam. They are 12" and have seen under 3 hours of music. If you are interested I could hook you up. Do you live in India?
Username: Nd4spd18
Southeast PA
Post Number: 2452
Out of those two I would choose the Type R
Username: The_image_dynamic
San Diego
Post Number: 1344
Funky Pups > Keeker
Username: Joebruce
15 Inch Wang...
Post Number: 887
I would take the type rs over the kickers. I had a pair of 12" old model type rs and they got loud and sounded really nice.
Username: Aman2005
Post Number: 424
@John, yes I Am from India.
That means IS hould go for Type Rs.. ok
So another question is the car has stock alt (70-80 ampere) installing an amp of around 1000 RMS will be ok with that or should I have to change the alt? I dont upgrade, any effect on electrical system?
Username: 420alldaylong
Post Number: 1733
Type Rs
