Thinking hurts!!!!! Help wiring 8 subs to certain ohm load....
Username: Thomas_g
NM
Post Number: 2333
Ok like i said im going with 8 12" pioneer premiers. I need to get all 8 down to a 2 ohm load bridged, or in stereo on my amp on each channel a 1 ohm load. i was thinking getting them all dual 2 ohm then series wire each sub for 4 ohm then parallel 4 subs to be 1 ohm load right? Then the same to the other four is this correct? Thanx.
Username: Jesse59672
OK
Post Number: 336
you lost me. but 8 12's badass. i have one 12 and i'm going for 146-147db
Username: Thomas_g
NM
Post Number: 2334
Wired like this.
Yeah i hope to hit over 150 db with this setup at the comp.
image/bmpUpload
Username: Thomas_g
NM
Post Number: 2335
Grrrrrr damn pic came out too small!!!!
Username: Joebruce
15 Inch Wang...
Post Number: 889
You can do it like this for 4 dual 2 ohm subs to get 1 ohm to each channel
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=4&woofer_imp=3
Username: Budling
Cali USofA
Post Number: 340
Use pic one for 2 channel 1ohm
Use pic two for bridged 2ohm(take the two sets of four and wire down to 2ohm.
Username: Joebruce
15 Inch Wang...
Post Number: 890
^^haha beat you to it!
Username: Thomas_g
NM
Post Number: 2336
alright so then i was right, thanx alot man.
Username: Thomas_g
NM
Post Number: 2337
whoa two more posts while i was typeing(im slow) thanx alot guys.
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 2841
get 10K on them :-)
