I was looking at this stuff for my box, looks good but I let some dry to test it and it seems what ever you paint with it may also be sound proofed, good sh!t. I bought the kit so there is a one gallon of it, should be enough to do the box, which I preresonned and sanded to give it bite and I will do under the rear deck and the whole area between the shock towers. I thik because of the grit it will also give the expanding foam a good hold on everything when I seal it all up. I will post pics when I start...Polo.
Mike did you use there roller, from what I heard there ia a difference in standard rollers (theres is textured). Now did anyone try to brush it on and if so did it come out smooth or??. I want to paint the port area but that needs to be smooth. Also how strong is this sh!t, does it make your box feel tougher? Polo..
Huh, I didn't see herculiner at my autozone... It was a differnt name product. I put up a post recently on how I did it... I used flec stone and then spray on bedliner over it. I love the way it came out. Also, polo, don't sand with anything fine as if you were painting it. Use something real gritty like 60 grit. Otherwise the roller will slide instead of roll. Good luck man I wanna see how this herculiner turns out.
