CD EJECT DONT WORK
Username: Wild_willy
Richmond Hill, Ontario Canada
Hello, Im new here, I have an Alpine 7904 stereo and there is a cd stuck inside, the eject dont seem to work. Is this worth fixing or is it a relatively cheap unit?
Thanks.
Will
Username: Kpa2727
Post Number: 57
thats not a legit number please re check your model so i can futher assist you.
tips :
if the unit has a flip down or removable face it is typically set up 2 ways. ether there are contacts for the face and it is possible ones not making contact causeing eject not to function or theres the 2nd kind that has buttons behind the face and the button behind the face is stuck. if thats the case u will need to use a screwdriver or something simular to it annd push on the button. try to see if it makes a click noise and feels like it's working. re apply the face and try to eject again. becareful though i take no liability for your actions as i have dealt with this before and ur new to it.
Hi Keith, I appreciate your response. I double checked and that is the model number. It's an older unit, non face plate removeable, not even a complete pull-out type. Just a solid Alpine am/fm tuner CD player.
When I press eject, i can here it doing the function inside but nothing is comming out, it looks like there are 2 cds jammed in there so I'll try taking it partially appart to see if I can notice if it's getting caught on a lip or something.
Will
