New member Username: Pervie_palPost Number: 1 Registered: May-07 | I am thinking of getting a boss rip995 2000w to power my two 12" kicker L5's but cant find anywere if its 2ohm stable bridged. Plz help b4 he sells to someone else my email is clifcll@aol.com thks |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1290 Registered: Mar-04 | 2 ohm bridged stability is a pretty rare thing for 2 and 4 channel amps. The Boss definitely isn't. You can bridge it and wire the subs for 8 though -- that should get you maybe 300w to each sub. |
New member Username: Pervie_palPost Number: 2 Registered: May-07 | Plz help on the boss rip995 2000w 4ch amp. Only thing i can find far as specs on this amp is 260 x 4 @ 4ohms and 1000 x 2 bridged it doesent say wat ohm it is bridged. If u can help with anything plz do thks |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1291 Registered: Mar-04 | when bridged - the amp would be optimal at 4 ohms. That much you can be sure of. As far as the power -- well 260x4 @ 4's a lie, and 500x4 at 2(1000x2 bridged at 4) is most definitely a lie. It has 2x25A fuses which tells me it would be unlikely to produce much more than 600w - which is where I got 300w each to a pair of 4 ohms subs. If you bridge it into 8 ohms (I'm assuming you have dvc 2's) it would be less than 600 (or whatever it's best possible power is) but not by a lot. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1292 Registered: Mar-04 | when bridged - the amp would be optimal at 4 ohms. That much you can be sure of. As far as the power -- well 260x4 @ 4's a lie, and 500x4 at 2(1000x2 bridged at 4) is most definitely a lie. It has 2x25A fuses which tells me it would be unlikely to produce much more than 600w - which is where I got 300w each to a pair of 4 ohms subs. If you bridge it into 8 ohms (I'm assuming you have dvc 2's) it would be less than 600 (or whatever it's best possible power is) but not by a lot. |
New member Username: Pervie_palPost Number: 3 Registered: May-07 | Hi I just got a concept cd-2410 and i want to power two 12" kicker L5's. the subs are duel 4ohm. Can anyone help me with this plz? clifcll@aol.com is my email thks |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4594 Registered: Dec-05 | If they're dual 4 ohm then grab 1000w rms at 1 ohm. Hifonics bxi 1206d can be useful for you. Post the ratings on that concept. |
New member Username: Pervie_palPost Number: 5 Registered: May-07 | The concept cd-2410 amp i have puts out 600x1 @ 4ohms,1200x1 @ 2ohms and 2400x1 @ 1ohm. The specs are at www.conceptcaraudiovideo.com Does anyone know the best way to wire two 12" kicker L5's to this amp they are duel 4ohm subs. This is my email sledgehammer302000@yahoo.com thks |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4596 Registered: Dec-05 | the12volt.com hit the link woofer wiring. You should set your gain with a DMM if it's true the output of that amp which i doubt. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1302 Registered: Mar-04 | your 2 options with a pair of dvc 4's are 1 ohm or 4 ohms. With a pair of 600w subs I don't think 1 ohm would be a reasonable option. That's 1200w per sub. 4 ohms isn't great either because it only gets you about 300w per sub, but underpowered subs are better than blown subs. That amp should bring you pretty good coin on ebay -- it should more than cover a decent amp that's around 1200w at 1 ohm. |
