Help me with my xm radio please
Los Angeles, CA USA
Post Number: 12834
i just got the pioneer GEX-FM903XM. it is the universal one so you can use with any hu or with the pioneer hu's for more features.
anyways it has 2 xm antenna connectors. one says "satellite" and the other says "terrestrial". which one do i connect it to?
please help me asap. i want to start listening to mx radio as soon as possible.
Username: Solo67042
KANSAS
Post Number: 183
i believe the satellite connector is where you will plug in the xm antenna and the terrestrial connection is where you will plug in the existing anenna from your car. the xm kit that i had had both inputs for both antenna and then one solitary output to the HU.
