New car and HU - What speakers should I get??
Username: Ryant
I just got a 2004 Toyota 4Runner and am getting a Pioneer Premier DEH-P790BT installed ...
I am now looking at speakers and am confused as to what I should do. I want to spend around $300-400 on speakers. The guy at Tweeter really recommends the Focal 165A components. I was thinking about getting these and adding rear coaxials later (or maybe not at all). However, I do not know if I will get an amp in the future and have heard that I may be more satisfied just buying coaxials in the front and back (The Pioneer Premier TS-D601P coaxials were recommended).
Again, I don't have a huge budget and don't know how much I'll add in the future in terms of an amp or subs. I want good SQ and something obviously better than my factory systems.
Thanks in advance ...
Username: Mrbass
Long beach, California United state
Post Number: 95
what the, theirs no such as that model
Username: Ryant
no model for what?
the headunit ...
2076_310069882_338834014%2C00.html,http://www.pioneerelectronics.com/pna/v3/pg/p roduct/details/0,,2076_310069882_338834014,00.html
component speakers ...
http://caraudiosecurity.com/shop/product/products_id/2767.html
coaxials ...
2076_310069896_192089293%2C00.html,http://www.pioneerelectronics.com/pna/v3/pg/p roduct/details/0,,2076_310069896_192089293,00.html
Username: Sinful_systems70
15 INCH WANG...
Post Number: 831
Might want to fix your link...nevermind, I will.. HU= http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&Pro ductID=18379
15 INCH WANG...
Post Number: 832
This one too... Coaxials= http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&Pro ductID=14553
Username: Mrbass
Post Number: 102
ok i saw it now, its the 2007 model, its good but the preout went down to 4v, and instead of 16band eq, it decrease to 7band and the most important for it to have is the 24 bit burr brown so thats a big deal to downgrade, so for that price you can get the p980bt which has the blutooth and all of the features i said
Username: Ryant
Post Number: 9
i am just looking for some good speakers to replace the factory ones. i really doubt i will be getting an amp or sub in the future. any suggestions?
Username: Oleg
Santa Monica, CA USA
Post Number: 1301
My personal opinion on this is that if you're spending $300-400 on higher end speakers, it's REALLY advisable to spend money on an amplifier because that's what makes them come alive and perform to their potential. You can try it off the HU first and if you like it, you can stick with it.
Username: Tc_skier
Post Number: 191
no dont try it off the HU. just spend the money and get an amp. you'd be an idiot to buy a $400 set of comps and then give them 18 watts. you'll prolly end up clipping the hell out of them and throw the $400 down the drain. skip the rear coax's and get an amp. i personally like the eD nine.2 which should power an average set of comps very well. i myself run a nine.2x because my comps can eat about 230 rms, but for anything such as iridiums or the focal's you listed above, 100-130 should be plenty. eD rates their stuff at 12.5v, not 14.4v like everyone else. so they're actually underrated compared to all others. if you call eD to place your order, they'll give you 10% off if you ask for it. or if you get an amp and a sub, the total package runs 15% off.
eD nine.2
http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=45
Username: Ryant
Post Number: 23
i don't have the money right now to get the comps and an amp. i may in the future, just not right now.
would i be better off getting coax's?
Username: Ctmike
Ct.
Post Number: 4253
if not getting an amp then yes, coaxs' would be your best bet.
Username: Ryant
Post Number: 24
what coax's would you recommend?
Username: Ryant
Post Number: 29
i just want a noticeable improvement over my factory components - will coax's provide this?
if so, which ones would you recommed?
Username: Oleg
Post Number: 1351
Yeah, most aftermarket speakers are a noticeable improvement over the factory ones. What's your budget for both sets?
Username: Ryant
Post Number: 30
i don't know - like $200 before installation?
that could either be for one good set in the front or 2 average sets in the back. i'm not looking for the best sq out there, just a noticeable difference over the factory speakers
thanks for your help!
Username: Ryant
Post Number: 31
... maybe even a little leess if possible.
Username: Oleg
Post Number: 1352
These should be good:
http://cgi.ebay.com/NEW-INFINITY-KAPPA-692-7i-6x9-2WAY-SPEAKERS-330Wmax_W0QQitem Z230127114557QQihZ013QQcategoryZ14942QQrdZ1QQcmdZViewItem
Don't get a rear set for now and see how you like the sound. You're getting a pretty nice HU, you'll be wasting a lot of its potential by not getting an external amplifier. If you get these infinities, you'll have about $100 left for an amp..you should definitely do that.
Username: Clouduz
Post Number: 211
yea, an amp is HIGHLY recommend to show any speakers true performance, most hu's just don't cut it. But that's not saying it will sound bad, you will just be missing a lot
Username: Kpa2727
Post Number: 24
infinitys do produce a hell of a sound esp from what ive used the rference 250w damn what clear audio u should notice a huge diff in sound without breakin the bank one bit even 6x9 3 way infinitys run under 200 in the 160 - 170 range for high rms but kappas are rated the best for infinity.
Username: Kpa2727
Post Number: 25
infinitys do produce a hell of a sound esp from what ive used the reference 250w damn what clear audio u should notice a huge diff in sound without breakin the bank one bit even 6x9 3 way infinitys run under 200 in the 160 - 170 range for high rms but kappas are rated the best for infinity.
Username: Oleg
Post Number: 1353
Yeah, I imagine they'd sound really good. We got a cheap set of alpine type Rs a while ago and they sounded really good as well. Ryan, you can get a pretty good amp for around $100 that'll make your entire system come alive...let me know if you need suggestions for an amp.
Username: Ryant
Post Number: 32
thanks to everyone for all the help! i don't know much about car audio but i'm trying to learn!
oleg, what amp(s) would you suggest?
Username: Oleg
Post Number: 1355
Either one of these would do the trick for you...
http://cgi.ebay.com/NEW-MTX-THUNDER-TC3002-2-CHANNEL-AMPLIFIER-CAR-AMP-TWO_W0QQi temZ280114493370QQihZ018QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Rockford-Fosgate-P3002-2Channel-300W-Car-Audio-Ampifier_W0QQ itemZ330117649467QQihZ014QQcategoryZ39732QQrdZ1QQcmdZViewItem
People on here like rockfords a bit more than MTX, but MTX does make solid amps - you won't be disappointed with either. Cosmetically though, I'd give a few brownie points to the MTX - not really fond of that particular RF design. BTW when you look at those amp specs, look at the 2ohm rating b/c those infinities are 2ohm speakers.
