Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1335 Registered: Dec-06 | my friend is looking for a sub and hes on a budget. he doesnt have much room so hes getting a 10" in a sealed box. The sub is going to be a: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2381 ^^^what do you think about that sub choice? Now for the amp and about 300rms which amp should he get? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3962 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4672 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4881 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4585 |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 892 Registered: Mar-06 | Hey Snarl, what kind of budget does your friend ave for sub and amp? Kevin |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1336 Registered: Dec-06 | he wants it to be as cheap as possible and he wants a sq setup with 1 10"sub in a sealed box. preferably less then 100 for the sub and less then 200 for the amp. he mostly listens to classic rock and just wants it to sound a little better. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2979 Registered: Jul-06 | Get the Kicker amp. Orion and RF are also ok. Don't get a profile. |
Gold Member Username: 420alldaylongPost Number: 1884 Registered: Sep-06 | http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3754 Put this sub in 1cf-1.25cf sealed and your friend will like. http://www.sonicelectronix.com/item_3407_Kicker+05CVR124.html |
