Any difference?
Username: Panocha
Post Number: 227
would i notice a huge difference if go from 800rms to 1300rms? With the same single 12" sub? thanks
Username: Jblanford
Post Number: 1048
what sub ? it probably won't be a HUGE difference but you should notice it
Username: Nd4spd18
Southeast PA
Post Number: 2367
I'd say it would be a very slight difference. Theoretically, doubling power gains you about 3 db. 1 db is the least you can notice a change, so yes it say you will notice it, but if won't be much difference.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2780
what about giving a sub 500rms and jumping to 2000rms... then jumping to 3000rms
on a sub rated at 2K.....
