No or bad signal
Username: Guatefreddie
Hey pals, Hi, once again I am asking for help, the image disappears and the receiver displays the message "no or bad signal" during several times a day, the antenna hasn't been moved, and without any doing of my part the signal returns... hours later. Has anyone this problem? What can it be? What can I do, please advise.
Username: Lklives
Post Number: 9494
sounds like a bad cable/connection or switch going bad..
Sorry what do you mean by a "switch" I checked a couplke of minutes ago and some channels do work but others don't??? I can see PPV on 509 but not PPV 505 and PPV 502, some HBOs do and others don't????????
Username: Mrskullz1
Brooklyn, New York
Post Number: 411
a switch would be something such as a multidish switch/diseqc switch. You can find out if you have one if these switches if you check your cable coming from the lnb(dish on ur roof) and see if it attaches to something other than your receiver first..then you have another wire coming into your receiver.
I'm sure its either a switch/or cable as lk stated above. In which both are simple to replace tho the cable might be a pain in the @ss for some.
Also when u get this message...just try a simple reboot from the back of your receiver and it 'may' fix it.
Username: Nydas
Post Number: 2670
Fred Battle : Can you post your receiver name and the BIN?
