Silver Member Username: Hoosier_daddyPost Number: 130 Registered: Dec-06 | Ok... Paragidm PS1000 how do I hook up to my reciever. I have just a run of the mill (crummy) JVC reciever. I went and bought a sub-woofer cable. Do i run from the high pass output or the low level input to the rec? I am assuming the high pass... Anyone know where I can downlaod a copy of a user guide for this...? Thanks in advance |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 285 Registered: Feb-07 | I am assuming your receiver does not have a RCA subwoofer pre-out on the back? |
Gold Member Username: NuckPost Number: 8647 Registered: Dec-04 | http://www3.sympatico.ca/turbod/hometheater/sub_woofer.htm It says mono lfe out from the receiver or pre-outs from the receiver. Which one do you have? If neither, use speaker level outs, paralleled from the speaker outputs with speaker wire. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11274 Registered: May-04 | . "Do i run from the high pass output or the low level input to the rec?" I'm guessing you want the sub to play. If there is a high pass output, it won't output low frequencies for a subwoofer. If you run from an input on the receiver, there will be no signal coming out of the receiver. For $5,000, would you like to call a friend? . |
Gold Member Username: NuckPost Number: 8652 Registered: Dec-04 | hehehe HD, you are running outputs from the receiver to the sub. You have to understand the basics before we can help you much. The sub outs run to the sub, the only inputs to the receiver are sources.okay? List your options and the receiver model# and we can help. |
