Bronze Member Username: JamesleePost Number: 22 Registered: Apr-07 | Sonicview 8000 HD SV-HD8000 The brand new Sonicview 8000 HD is the hottest new high definition free to air fta satellite receiver that will give you all the best HD channels. Sonicview 8000HD is very easy to use simple to setup and with the sonicview 8000hd you get the best picture quality out. Sonicview high definition allows you to get 1080i on all the best channels with usb 2.0 port Sharp video tuner and much much more. Sonicview 8000HD Websites: Sonicview 8000 HD Features: * Dimension : 370(W) x 250(D) x 60(H)mm * Basic Color : Black Color : Black with Silver * Selectable Output Video Format : 1080i / 720p / 480p / 480i * 2 Tuners : ATSC Tuner(Sharp,NIM Type) & QPSK (Samsung, NIM Type) * USB 2.0 PVR Function Supported : 1 Channel Record & Play with an external HDD * Fully Comply with ATSC HDTV(VSB) & DVB-S MPEG 2 * EPG Supported * Close Caption Supoorted * 9 Characters 1 Line VFD Blue Display * Real Time Clock * Channel Naming Supported * Full Colors & User Friendly GUI for Easy Control * The Fastest Booting & Scan Speed * Single & Multi-Satellite Auto Scan * Manual Scan Supported * Highly Speedy Channel Changing Time : Less than 1 Sec. * 6,000 Channels Memory Capacity for TV & Radio Programs * 8 Favorite Channel List Group Programmable * Channel Sorting by FTA, CAS, Satellite, Alphabetic Order & Network * Muti-Picture Frame Screen Available * Stand-By for Low Power Consumption * 7 Controlling Keys Power On/Off, Channel Up & Down, Volume Up &Down, Menu, OK * F-Connector : TV Antenna-In * 1 LNB Input with IF Signal Loop Through Input Frequency 950 -- 2150 MHz Tuner Symbol Rate : 1∼45 MS/s * Supports SCPC & MCPC from C / Ku-band DiSEqC 1.0 & 1.2 USALS with 500mA Max LNB Power / 22KHz Switching Control Supported * 4, 9,16 Flame Screen & Thumbnail View Selectable * Zoom In-Out Function for Watching Screen * Various Aspect Ratio with4:3, Letter Box, Full Screen & 16:9 * Background Graphic Display for Radio Program Channels * Parental Lock Function using Master PIN Code * Automatic NTSC / PAL Detection and Simple Video Converter (NTSC <-> PAL) * RS232C 9-PIN Connector : Twisted Cable * USB 2.0 Host : For S/W Downloading * PC to Set S/W Downloading using Window based Specific Program * Set to Set S/W Downloading (Main Program & Channel List Data File) * RCA Output for Video, Audio L/R * Composite Video Output( Y,Pb,Pr) * Low Power Consumption Supported : Less Than 5 W in Stand-By Mode * HDTV HDMI Output Connector * S/PDIF for Digital Audio / Dolby AC-3 Bitstream Output * S-VHS Output Connector * Useful Universal Remote Control Unit 95~250 VAC 50/60Hz Universal IR Remote Control * 3 Phono RCA Cable, Serial Cable, 2 AAA Batteries for RCU & User's Manual Sonicview 8000HD or sonicview 8000 hd a powerful yet easy to use box. |
Bronze Member Username: JamesleePost Number: 25 Registered: Apr-07 | sonicview is one of the names in fta backed by viewsat support you get the best with sonicview 8000hd high definition |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1066 Registered: Oct-06 | Not only I think it is a bad HD receiver I don't think it is capable of MPEG-4 1080i (8psk bit rate) When devices say output 1080i most likely it is 720p with an upscale to 1080i output. If it doesn't say 8*PSK leave it alone don't even think about it Don't get dupped If Captvi*eworks start to sell MPEG-4 8PSK then it is the one you get. RIGHT NOW NOTHING TO BUY. I do think by the end of this year they'll get it right BE*V and DT*V they lower their resolution to save bandwidth where as D*N is the only true 1080*i MPEG*-4 8*PSK |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1067 Registered: Oct-06 | Virtually when they lower their resolution to fit more bandwidth they will claim "WE OFFER MORE HD BROADCAST THAN ANY PROVIDER." They think consumer would never detect resolution since they can't measure it. Thank god there is King Tapeman always looking for the best intrest of consumer. I detect the resolution by just looking at it. "I do this for a living" I don't hack I don't need to D*N and Cable on the other hand at present time got true 1080i. 1920x1080i where available. I hope this is a helpful tip to all my fellow FTA users to know what is out there. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 1832 Registered: Nov-06 | Ok is that why, when I scan echo 5/t7@129w I don't see a hd channel line up,but when I scan nimiq 2 @82w I can load the hd channel lineup ? |
Gold Member Username: Mc_sunnyPost Number: 1202 Registered: Feb-06 | -Sonicview and Viewsat HD...They will both do Mpeg 4 channels as well with 1080i resolution. -To get HD channels On DN you need to get 8psk module and adpator..If you are using the Sonicview 8000HD without the adapters. The only HD channels you can see will be on BEV !!!! This goes for Viewsat HD as well... |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1072 Registered: Oct-06 | You are right McCsunny I'm just saying make sure you buy an HD receiver that can handle 8*PSK 8PSK (bit rate) is the new broadcast standards for MPEG-4 I'm guessing that 82 is Q*PSK MPEG*-2 1080x720p DTV has been all along Q*PSK but not MPEG-2 and it is 1080x720p Lowest HD Broadcast considered 1080x720p I say guess cuz you can't measure it I'm 100% certain BE*V and DT*V are not 1080i Only D*N is 1080i Scanner if you load 82 lineup (fuzzy picture) Cuz they are MPEG-2 720p Many TIVOs and DVR they record HD in MPEG-2 Only Toshiba and Sony got limited MPEG-4 recorders and they are 2 different formats It is a bit complicated out there for HD consumer Listen to me don't buy it yet |
Bronze Member Username: SatscannerrPost Number: 31 Registered: Apr-07 | sorry Ok is that why, when I scan echo 5/t7@129w I see a hd channel line up,but when I scan nimiq 2 @82w I can not load the hd channel lineup ? |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 1851 Registered: Nov-06 | But cartier wants my load ! |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1074 Registered: Oct-06 | It is the other way around Yes to Your post# 1832 "when I scan echo 5/t7@129w I don't see a hd channel line up, but when I scan nimiq 2 @82w I can load the hd channel lineup?" I don't think you can load MPEG-4 with MPEG-2 coders. If you can load any channels with MPEG-2 coders cuz they are in MPEG-2 They could be MPEG-2 1080x720p (considered to be HD but low end) You can't load D*TV QPSK cuz they are not MPEG-2 If You can't load MPEG-4 cuz receiver is not capable of MPEG-4 What McCsunny says with an extra module you can get D*N MPEG-4 8*PSK 1080i. I do think it makes perfect sense but I still think if an HD receiver need extra hardware to decode MPEG-4 cuz it was never capable of it in first place. They can misslead by saying MPEG-4 accelarator or 1080i output. What I say don't buy any HD receiver that doesn't have: MPEG-*4 8*PSK 1080i DECODER If it doesn't say that chances that it is not If you want to buy extra modules to be able to get true HD 1080i broadcat I say it is cheaper to subscribe to get limited HD broadcast. You shouldn't have to pay extra money to make HD receivers decode HD Broadcast. Known as "Inferior receivers" |
Silver Member Username: Bones714Somewhere fi... Post Number: 356 Registered: Mar-05 | are there any receivers that are true hd with no needed hardware out there. What are they? I been reading bout the hd receivers and been getting different outputs. I only want DN programs. What satellites do i point to? How many channels is DN offering in HD? |
Bronze Member Username: AndreasmithPost Number: 19 Registered: Mar-07 | King Tapeman, Can i get HD Channels using cool*sat 8000HD? Your advice please Thanks Andy |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1159 Registered: Oct-06 | Only BEV for a limited time DN, as far as I know you can't: Not without additional hardware 8PSK MPEG-4 Decoder Module about $250 off e-bay What I'll do is: - Wait - Get an HD antenna - Or Subscribe It is a lot cheaper to subscribe than to own of these expensive and inferior receivers. - Not all channels in HD/24 hours at present time. For low cost HD/digital antennas click here: https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1062457#POST1062457 |
