Direct tv dish
Username: Youyou
Post Number: 7
can i use direct tv dish on 110 west or 119 , to receive dish network channels?????
Username: Johnner
Miami, Florida
Post Number: 1056
yes u can in fact all my dishes are DTVs.
Username: Youyou
Post Number: 8
thank u
Username: Tapeman
New York City in-HD, NY
Post Number: 1148
The Dish is OK
(Phase II or Phase III LNBs) will only get you either 110 or 119 but not both
Username: Lklives
Post Number: 9449
Using an 18 inch round single LNB DTV dish and adding/tying/clamping a 2nd LNB (poormans dish...110 & 119) works well...stay away from DTV 3 LNB dishes, as U will ONLY get 1 Bev and 1 DN satellite unless u add more LNB's and have much patience for that dish alignment purposes..
POORMANS DISH
Username: Nydas
Post Number: 2658
josef : The above solution suggested by LK is probably the best and most cost effective solution there is for your specific needs.
